Lower cylinder problem - any ideas?
timnsr250se
Mon May 02, 2005 3:30 am » Post: #1 » Download Post
Hey guys,
my mc21 basically isnt firing properly in the lower cylinder and i was hoping you guysmight have an idea whats up with it. I had it dynoed recently and it made 54 hp at 10000 rpm, but below 6000 its barley making 10 hp. There is noticably a lot more exhaust gases flowing out of the upper cylinder and the lower cylinder doesnt sound healthy Sad . And now occasionally the motor is just losing power all together and im scared the thing is gonna explode if io dont do something soon.
Do you think maybe the ignition timing is way off?
Or could it be the power valves, even thought they seem to work ok?
Would a blocked fuel jet cause this type of problem?
Do worn rings or ahole in a piston cause this?
Would this have anyrthing to do with the TPS or PGM or kiss DRbox?
When i took the bike to a mechanic a couple of weeks ago i said i wanted it rebuilt but they only replaced the head gaskets and said it didnt need a rebuild, which im not entirely happy about.
Any help whatsoever would be really really appreciated,
cheers,
Tim
timnsr250se
Mon May 02, 2005 4:07 am » Post: #2 » Download Post
just had a look at tygas agony aunt page and they mentioned sticking carb floats, and recently after i rev the bike a bit and pull the clutch in, the revs drop to about 3000 and then dont drop further, related to my cylinder problems maybe?
Is it possible for something wrong in carb setup to affect only one cylinder and not both?
thanks again
tim
