Idle screw broken?
joeking78
Idle screw broken?
Sat Apr 30, 2011 4:30 pm » Post: #1 » Download Post
I found the idle screw on the left side of the MC21 under the tank but it doesn't matter which way I turn it never seems to get to a point where it stops...is that right?
I have a funny feeling its come loose from the carbs, if that can happen but I can't check as it's pitch black outside.
Any assistance would be greatly appreciated.
joeking78
Sat Apr 30, 2011 6:22 pm » Post: #2 » Download Post
Well that was a midnight mission!
Took a torch out, tank off, carbs off and sure enough the idle screw was not attached. Found a little spring, washer and small bracket so put it all back together.
It started but after a few seconds the revs started to climb, when it got near 5k I cut the engine. Will have to investigate this further tomorrrow as I tried to start it again and it wouldn't have it.
joeking78
Sat Apr 30, 2011 6:45 pm » Post: #3 » Download Post
Just took the plugs off and they are as black as you can get, running very rich so its probably flooding.
I think the reason the revs are climbing is because I haven't seated the carbs in the manifolds correctly as it was too dark to see what I was doing properly.
Will sort this all out tomorrow and may mod the airbox to lean it out a bit.
pvan340
Sun May 01, 2011 4:13 am » Post: #4 » Download Post
Might be a good idea to get it running right before chopping the airbox up? Have you had the carbs off and cleaned them? Checked the float levels? Balanced the carbs? If you have a search on here, there have been other users with the same rizing rev's problem, and these have been some of the solutions. Could be rich because of the float not set right? New plugs I assume? If its got standard jets in it and nothings been touched engine or pipe wise it should caburate pretty well, honda got them pretty well dialled. One symtom of rising revs is an air leak, like you said, the carbs might not be seated correctly, or it could be crank seals, especially if it has sat for a while. I know Dubai is dry and all but still.............
Just my 2 cents worth, but that's where I would start before cutting away and potentially masking (or creating) another problem.
joeking78
Sun May 01, 2011 5:26 am » Post: #5 » Download Post
The rising rev thing only happened after I took the carbs off so it must be that I put them on incorrectly.
It started after about 5 kicks when I started it for the first time and ran fine but I start fiddling with the idle which is when it all went pear shape, especially when the idle screw fell off!
It's totally stock. Put new plugs on it last night. Will play some more when I get home from work. I will need to clean the carbs though I think.
joeking78
Sun May 01, 2011 5:16 pm » Post: #6 » Download Post
Finally sorted the over reving & hard to start problem.
Turns out when I had the carbs off I didn't seat them correctly into the airbox so there was an air leak. Also, I kinked the fuel tank breather hose and one of the carb breather hoses.
Video below.
http://youtu.be/tXSbX0spgDE
Its running very rich, probably wasn't in Japan but here in Dubai it is...you can hear the bogging as I open the throttle and it doesn't want to be ridden at all, as soon as I release the clutch in first gear the revs drop...needs some fine tuning which I'll have to do at the weekend.
chucky
Sun May 01, 2011 5:23 pm » Post: #7 » Download Post
it is the weekend
if dont fall off every now and then your not trying hard enough
joeking78
Sun May 01, 2011 5:36 pm » Post: #8 » Download Post
chucky wrote:it is the weekend
Not for me here in Dubai...weekend is Friday/Saturday not Saturday/Sunday so mine is over, started work this morning.
chucky
Sun May 01, 2011 6:35 pm » Post: #9 » Download Post
fair enough Wink
joeking78
Sun May 01, 2011 7:03 pm » Post: #10 » Download Post
My bike is obviously very rich from plug colour and bogging...Should I buy smaller jets or will I get the same effect by drilling 4 x 20mm holes in the front slope of the airbox?
dunkenb
1989 Honda NSR250 MC18
Sun May 01, 2011 7:18 pm » Post: #11 » Download Post
I'd go with jets after you've drilled the airbox lid,as the extra air flow can also draw more fuel! Very Happy
chucky
Sun May 01, 2011 7:21 pm » Post: #12 » Download Post
check the jets first see if thjey are a standard size
joeking78
Sun May 01, 2011 7:23 pm » Post: #13 » Download Post
Will get the carbs off tomorrow...again Wink Will give them a good clean whilst they're off.
Any place you guys recommend to buy jets?
chucky
Sun May 01, 2011 7:25 pm » Post: #14 » Download Post
you have never raced a 2 stroke each time you ride it you take the carbs off
chucky
Sun May 01, 2011 7:27 pm » Post: #15 » Download Post
and the barrels every day which means the pipes too, and the wheels alot
