hi
i have a 21 rear shock for sale it is from a r model (will have a sp unit as well shortly)
dont now if it will fit an 18
but i am sure andy will reply with the answer to that shortly
Thanks Nigel, Im told a 21 shock will fit into an 18 (its alittle longer so i beleave but i dont know by how much) an SP unit would be great tho. Mines only an MC18R5k and an R model but i like the rear of my bikes to be pretty high and im pretty big so the adjustability of an SP unit woudl be perfect. Any ideas of how much you want for the SP unit? You can email me at StephenRC45@aol.com if you like
I can tell you that the MC18 rear shock dimensions differ significantly from the MC21/MC28 units, and that I've also never heard of anyone trying to fit (let alone successfully fitting) a later shock to an '18!
I have some HRC F3 diagrams for new linkage plates however, that will raise the standard setup a little, and will post them on the Messageboard this evening if I can find them!
The NC30 shock is extremely similar to the MC28, but with a harder spring/damping I believe (due to the VFR's unsprung weight) but I have not personally tried to fit one to an NSR.
I would've thought it would be a perfect excuse for Charles to get out into the garage and measure his NC30 shock against his MC21 road-bike AND his MC28 race-bike shocks, allowing you to then compare the measurements to your MC18!
Thanks andy.. that would be great if you could do that and i can make myself a set
ps i am a member but for some reason each time i put my user name in it says its taken... i know its taken... its taken by me. so i give up lol im staying as a guest.
Thanks andy.. yes very useful, the bike is away for a min being repainted so as soon as i get her back i will make a set up and see how she goes. thanks for your efforts
