As I've figured out I have a quick turn throttle on the bike, I was curious if this had any impact on the oil pump. There wasn't much info on the matter when I searched (or I was using the wrong search words), but some seemed to think it was OK and others said not OK.
I've experimented and have concluded that running a quick turn shouldn't matter, since the oil pump cable is connected to the carb end (buttery valve for a lack of another name to call it). The throttle cable still moves the same distance as a stock setup would.
Anywho, I've adjusted the oil pump cable so that with 1/2 throttle, the first alignment mark lines up. But should the second mark line up at WFO (wide F-in open)? I plan on going really fast (lmao) and want to make sure I don't grenade it the first time out. Is it better to give it more oil than less for going fast in higher rpms?
Thanks!
Dana
2016 Husqvarna 701SM
2021 Husqvarna FS450 supermoto
1995 NSR250r MC28
