Finally tuned...
javes
Finally tuned...
Sat Oct 22, 2011 8:04 pm » Post: #1 » Download Post
I have managed to put everything in place.
After seizing the front cylinder, and some incorrect assembly, a bit of loving care has finally brought things were they should be. This is a 21 R engine with the wire spliced, a fresh top end and TYGA hi flow reeds. Other than this, I have new std jets and adjusted RC valve 'the HRC way'.
As soon as I completed the RC valve adjustment, I realized how the engine behaviour had changed, but yesterday I got the dyno readings. My friend and dyno owner has a vj22, which also puts 55 rwhp, but the power curve from the NSR is consistently +/- 5 hp above the rgv. He would not let me have a chart with both curves!
In any case, I am pretty happy with the throttle feeling, as happy as to not consider drilling the airbox lid. Not for street use.
Thanks for all the advice. I can now go and try to improve the aesthetics on my bike.
Sat Oct 22, 2011 10:13 pm » Post: #2 » Download Post
The NSR motor is so much better than an RGV in every respect. Honda really put some thought into it, Suzuki didn't.
Re: Finally tuned...
Sun Oct 23, 2011 12:23 am » Post: #3 » Download Post
Good result, but modifying the lid would see you with around another 5hp! You wouldn't lose out in the bottom/mid-range either.
javes
Sun Oct 23, 2011 9:30 am » Post: #4 » Download Post
You are right, Stephen, and that's something known by every NSR owner. I only made the comment because you should have seen the face of my friend. This is NSR world!
Andy, I know, but I use the bike 99% on the street. I've been only once on the track. It is true that I have not repeated 'couse the bike was not 100% and now it is, so I plan to return soon (what a shame the UK is so far from me). But I am still considering the 5hp gain at ¿10k-11k? with the potential loss in reliability/longevity. The other reason to leave it as is, is that I am no real mechanic. It seems that everything I touch goes wrong, and then I need extra time to put it back in working order LOL.
As it is now, riding on open roads with the engine between 7-10 k is a real pleasure! However, I have a range of jets seating in my garage, in case the lid is to be modified. I have an idea in the back of my mind...
jorgea
Finally Tuned
Sun Oct 23, 2011 4:29 pm » Post: #5 » Download Post
Your cycle sounds like it's ready to race. It takes time to get the engine perfectly where it ought to be.
