dry clutch replacement
mrkeung
Thu Apr 05, 2012 9:51 pm » Post: #1 » Download Post
Hello,
Can I have any suggestions and advices on clutch replacement for my 90 SP? I am looking for the most affordable and appropiate set up for my stock trackday bike.
Thank you so much!!!!
Sam
Neal
Fri Apr 06, 2012 6:17 am » Post: #2 » Download Post
Order some fibre plates from Tyga Performance and have your steel plates blasted , add a extra washer to the bolts when you refit them for some extra tension .
NSR-lizard
Fri Apr 06, 2012 7:31 am » Post: #3 » Download Post
Heaven forbid you promote this site! Rolling Eyes
http://nsr-world.com/marketplace/product_info.php?products_id=113
http://nsr-world.com/marketplace/product_info.php?products_id=144
and about 3/4 of the way down this page for some more info.....
http://www.nsr-world.com/tuning/250-tuning/engine/
Vampire?
Neal
Fri Apr 06, 2012 10:40 am » Post: #4 » Download Post
Your deep rooted anger / resentment or whatever you have against me has blinded you Lizzy .
The guy asked for a cheap option . Fibre kit from Tyga is 66.38 pounds . Fibre kit from market place is 89.99 pounds .
Fri Apr 06, 2012 3:48 pm » Post: #5 » Download Post
If your going to add a washer to pre load the clutch springs remember the washer must be able to fit over the centre (ie be able to slide down). If you use a normal washer it will do nothing apart from look pretty.
Fri Apr 06, 2012 4:01 pm » Post: #6 » Download Post
Preload the springs? What is this, the 1970's and an RD?
mrkeung
dry replacement
Fri Apr 06, 2012 4:47 pm » Post: #7 » Download Post
Hi,
First, thank you for the info. Is there any order part(s) I need in additional to the NSR-WORLD SPL Dry clutch Kits?
Thank you for your help!!!
Fri Apr 06, 2012 5:35 pm » Post: #8 » Download Post
The SPL "dry clutch kit" is complete... nothing else required, although while it's in bits you could add a pushrod seal, but it's not common for them to fail.
The SPL "dry clutch plate kit" simply replaces the OEM fibre plates.
I could add OEM fibre plates to the Marketplace, but I don't think I would be able to do them significantly cheaper. There is absolutely nothing wrong with OEM plates and springs on a stock, or even mildly tuned motor, if you don't want to "upgrade".
mrkeung
Sat Apr 07, 2012 6:36 pm » Post: #9 » Download Post
Thank you so much Andy!!!!
Can you please tell me the best and most affordable channel to order one of those SPL clutch kit to California, USA?
Thank you
Sam
