Can I have any suggestions and advices on clutch replacement for my 90 SP? I am looking for the most affordable and appropiate set up for my stock trackday bike.
Order some fibre plates from Tyga Performance and have your steel plates blasted , add a extra washer to the bolts when you refit them for some extra tension .
If your going to add a washer to pre load the clutch springs remember the washer must be able to fit over the centre (ie be able to slide down). If you use a normal washer it will do nothing apart from look pretty. _________________ If I have to take the carbs off once more...
The SPL "dry clutch kit" is complete... nothing else required, although while it's in bits you could add a pushrod seal, but it's not common for them to fail.
The SPL "dry clutch plate kit" simply replaces the OEM fibre plates.
I could add OEM fibre plates to the Marketplace, but I don't think I would be able to do them significantly cheaper. There is absolutely nothing wrong with OEM plates and springs on a stock, or even mildly tuned motor, if you don't want to "upgrade". _________________ Andy.
