gonna start rebuilding my engine
now i got some spare cash
but need to get this damm flywheel off
can anyone in the uk give us a link for a flywheel puller please
dont wanna use a leg puller though just aint to sure which flywheel puller is for my nsr250
thanx for the secret part number location andy
me thinks ill look first before i ask a question in future
with the help of Stephen looks like ill be getting me puller real soon
StephenRC45 big thanx for sending me the puller m8
and of course andy for them secret numbers #####-#######
well i gave the puller a go last night in work but had a prob
i put the left handed screw on the flywheel then screwed the centre bolt in as far as possible which went straight into the crank where the bolt retains the flywheel
but it stripped the thread inside when we tighten it up
so we sorted the stripped thread
then took the measurement of the diameter of the crank end
then lathed a piece of metal to act as a spacer exactly the diameter of the crank end
so the screw dont go into the crank when tightened
i know the part number was right cos it was stamped with them magic numbers #####-#######
so i'm just wondering if the centre bolt should go into the crank
or should rest on top of the end crank
well i'm sh*t at explaning things most times
so i hope someone can make sense of what iv'e just said
incase someone else has the same prob
I think i understand what you have done there Stevo. Sometimes you do have to fit something onto the end of the cranks to stop the puller mushing the end of the crank. What you did sounds right. We normaly turn down the head of a bold and screw it into the crank before using a puller on it. I guess you did get the flywheel off tho??
