flywheel puller
stevo
flywheel puller
Mon May 03, 2004 4:04 pm » Post: #1 » Download Post
gonna start rebuilding my engine
now i got some spare cash
but need to get this damm flywheel off
can anyone in the uk give us a link for a flywheel puller please
dont wanna use a leg puller though just aint to sure which flywheel puller is for my nsr250
Mon May 03, 2004 8:01 pm » Post: #2 » Download Post
Hi Stevo,
The puller is a standard Honda part. If you read the engine strip-down section in The Workshop you will find the Honda part number.
Sure, I could've just told you the part number, but there isn't much info you can't get from a little reading though the Site!!!
Mon May 03, 2004 8:06 pm » Post: #3 » Download Post
lol, Its the thrill of the hunt thats the fun hey andy? You cant just "give" part numbers away lol.
Mon May 03, 2004 8:11 pm » Post: #4 » Download Post
When you're right, you're right, Stephen! And you, you're always right!! :D
Actually, I guess you could supply a puller to anyone in the UK should they contact you, correct?
Mon May 03, 2004 8:20 pm » Post: #5 » Download Post
Yes I can do that. If its a stock Honda part I should have it within 2 days if Stevo needs one.
stevo
Tue May 04, 2004 5:30 am » Post: #6 » Download Post
Andy wrote:Hi Stevo,
how the hell i missed that is beyond me lol thanx andy
ill grab the puller from u StephenRC45 if you pm me details m8
Tue May 04, 2004 8:37 am » Post: #7 » Download Post
Stevo: No prob's...
Stephen: Make sure you ask him for that part number... don't you go giving it away!! ;)
:D
Guest
Tue May 04, 2004 9:36 am » Post: #8 » Download Post
lol too late Andy, ive already ordered one.
I have all your prices too andy. I will send them onto you when i get home tho... some arnt that bad infact Wink
stevo
Tue May 04, 2004 4:36 pm » Post: #9 » Download Post
thanx for the secret part number location andy
me thinks ill look first before i ask a question in future Embarassed
with the help of Stephen looks like ill be getting me puller real soon Wink
Tue May 04, 2004 5:55 pm » Post: #10 » Download Post
Is that the "secret" location with the diagram and the part number highlighted in red by any chance?!!! ;)
Yeah, I did my best to camouflage that one! :lol:
stevo
Sun May 09, 2004 6:08 am » Post: #11 » Download Post
StephenRC45 big thanx for sending me the puller m8
and of course andy for them secret numbers #####-####### Shocked
well i gave the puller a go last night in work but had a prob
i put the left handed screw on the flywheel then screwed the centre bolt in as far as possible which went straight into the crank where the bolt retains the flywheel
but it stripped the thread inside when we tighten it up
so we sorted the stripped thread
then took the measurement of the diameter of the crank end
then lathed a piece of metal to act as a spacer exactly the diameter of the crank end
so the screw dont go into the crank when tightened
i know the part number was right cos it was stamped with them magic numbers #####-#######Wink
so i'm just wondering if the centre bolt should go into the crank
or should rest on top of the end crank
well i'm sh*t at explaning things most times
so i hope someone can make sense of what iv'e just said
incase someone else has the same prob
Sun May 09, 2004 9:30 am » Post: #12 » Download Post
I think i understand what you have done there Stevo. Sometimes you do have to fit something onto the end of the cranks to stop the puller mushing the end of the crank. What you did sounds right. We normaly turn down the head of a bold and screw it into the crank before using a puller on it. I guess you did get the flywheel off tho??
stevo
Sun May 09, 2004 3:51 pm » Post: #13 » Download Post
yeah i did turn down the head of a bolt and the flywheel came off really easy
just thought ad mention incase someone else gets a bit puzzled
Sun May 09, 2004 4:19 pm » Post: #14 » Download Post
Bold = bolt, sorry
Mon May 10, 2004 8:41 pm » Post: #15 » Download Post
This may demonstrate the best method to remove the flywheel.
The "rotor puller attachment" is an NSR special tool, Honda part# 07HMC-KV30100.
Stevo and Stephen's method of turning down a bolt head does exactly the same job though.
