Ignitech unit
Page 1 of 4  Goto page 1, 2, 3, 4  Next Download Topic
Neal
Ignitech unit
Fri Sep 07, 2012 7:07 pm » Post: #1 » Download Post
Has anyone here installed a ignitech unit on their bike and is willing to do a step by step guide for dummies ?
TuckerBag
Sat Sep 08, 2012 4:55 am » Post: #2 » Download Post
I am probably going to install an Ignitech on my bike sometime in the next year or so. Don't wait for me though, I'll be slow to get around to it.
I just like the idea of having a bit of a play-around with the ignition and powervalve timing.
No doubt it will cost me a few pistons and/or barrels. Smile
I believe that Ignitech have a program all mapped out ready to go for the NSR. But it was third hand info, so best to ask Ignitech direct.
Neal
Sat Sep 08, 2012 11:59 am » Post: #3 » Download Post
Yip , it comes preset with a curve for the mc18. My challenge is to learn how to alter things slightly to mach my state of tune , which is difficult if there are no instructions that I can find .
tasos
Sat Sep 08, 2012 1:43 pm » Post: #4 » Download Post
Neal, this friend of mine did it,
just installed ignitech on his TZ
http://brokenpiston.blogspot.gr/
I will ask him to contact you, somehow.
Kostas Dee
Sat Sep 08, 2012 6:31 pm » Post: #5 » Download Post
It takes a lot of process to get it done but when you get there you'll be more than happy,it sure worth to try.
Neal
Sat Sep 08, 2012 7:35 pm » Post: #6 » Download Post
Thanks , we will be setting it up tomorrow and i will update those that are interested .
2Smoke
1987 Honda NSR250 MC16
Sat Sep 08, 2012 7:40 pm » Post: #7 » Download Post
I'm interested. I really fancy being able to adjust the PV's on my NSR.
Is there not some reliability issues with the Ignitech units though?
Neal
Sat Sep 08, 2012 8:39 pm » Post: #8 » Download Post
Not that i am aware of , if there are any problems they are sorted out asap by the manufacturer . Its all good and a step forward in developing the bike .
The price is not too bad either so i will see first hand if it is worth it or not . We are expecting a beter midrange with a better overrev too . Very Happy
Neal
Sun Sep 09, 2012 5:54 pm » Post: #9 » Download Post
It starts and runs , the power valves are doing there thing so looking forward to the dyno session on the weekend .
Mon Sep 10, 2012 9:07 am » Post: #10 » Download Post
We did a test which suggested getting the PV's open slightly earlier could be advantageous; we did as power run, killed the ignition at full revs, then unplugged the PV unit and did another run (so the PV's were as open as they get).
Obviously the curve with the PV's fully open was worse at the bottom but it crossed the normal curve and made more power for a few hundred revs just before peak power.
Neal
Mon Sep 10, 2012 3:56 pm » Post: #11 » Download Post
Thats what i am looking for , if we get a little bit extra anywhere on the curve then i am happy
greggo
Tue Sep 11, 2012 2:03 am » Post: #12 » Download Post
Curious to see how you go. I'd like to use one of these on my next project - once i find a donor and assuming that donor is an NSR!
nxrsr20
Tue Sep 11, 2012 10:16 am » Post: #13 » Download Post
are you chasing another NSR greggo?
greggo
Wed Sep 12, 2012 3:53 am » Post: #14 » Download Post
Sort of. At the moment I either want the pro-arm RS250 and rejet/modify it to run on pump gas (i know they aren't the best performing of the bunch but i've always had a boner for them) or build another NSR on an MC28 base but put my fresh engine in it with USD forks, and put together another runner in my current frame but most likely with freshened up stock pipes and a few mods.
Something like that.
Was planning to collect bits, maybe a 28 swinger here, forks there, crappy engine...slowly start work...so the missus doesn't notice me building and spending...
2Smoke
Tue Sep 18, 2012 7:21 pm » Post: #15 » Download Post
Neal, which model did you go for? Is it the combined ignition/pv controller setup?
Paul
