Testtank, where to buy?
pbekkerh
Sun Oct 14, 2012 8:04 pm » Post: #1 » Download Post
I am looking for a testtank for working on the carburators but I've only found one that costs 65 USD.
I'm talking about a 1 liter bottle with a quickconnect to install while testing.
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
Sun Oct 14, 2012 9:00 pm » Post: #2 » Download Post
Make your own...
TuckerBag
Mon Oct 15, 2012 5:53 pm » Post: #3 » Download Post
I have always wanted to make a little test tank using one of those Aluminium Heineken Beer Mini-Kegs that you see in the supermarkets. Smile
But you need to somehow add a fuel tap and filler cap. Could be a little bit tricky. But good "street cred".
Lane
Wed Oct 31, 2012 12:10 am » Post: #4 » Download Post
I use a plastic sauce squeeze bottle.
The pointy nozzle allows easy fitment into any size fuel hose too.
pbekkerh
Wed Oct 31, 2012 7:50 pm » Post: #5 » Download Post
Dave Ett wrote:Make your own...
I did. it worked a while, now its leaking and the lid is very difficult to open/close. I guess it was the wrong plastic type.
Poul
MC21SE, KISS box
Wed Oct 31, 2012 9:34 pm » Post: #6 » Download Post
I made one by using a plastic fuel can. Get a bolt which will fit into the fuel line, and drill a hole right down the middle of it, as big as is sensible without ruining the strength.
Now drill a hole in the bottom of the fuel can slightly smaller than the bolt so you have to screw the bolt in.
Make the hole in line with the filler hole so you can get a socket onto the bolt head. Screw the bolt through from the inside, and fit a locking nut on the outside. If you got the hole sized right it'll seal perfectly against the bolt. If not, you'll have to use chemical metal to seal it.
You can now fit a length of hose to the can with an in-line connector to fit your bike fuel pipe - the kind that seal when you disconnect them (that you probably have anyway as fettling a two stroke requires lots of tank removal!)
Now you have a can you can easily fill, has a handle for hanging it up, and will fit onto the fuel line of the bike.
If you wanted to, you could put the bolt through the sidewall below the filler such that the can will still sit flat on the floor when not in use...
Wed Oct 31, 2012 9:38 pm » Post: #7 » Download Post
Seriously, just but a Honda GX--- [generator] fuel tank and mount it on a little alloy bracket! They're all of about £20! Rolling Eyes
nobby62
Wed Oct 31, 2012 9:51 pm » Post: #8 » Download Post
get a 2-stroke oil bottle (with the retractable long plastic filler tube) cut the botton off, turn it upside down and the thin plastic nozzle will just nicely squeeze into the fuel line to create a seal ...... job done.
Wed Oct 31, 2012 11:06 pm » Post: #9 » Download Post
Keep them coming! Smile
Middo
Thu Nov 01, 2012 9:25 pm » Post: #10 » Download Post
I went to our local large hardware chain and got some suitably sized hose and a small inline tap for air powered tools. I can connect this to the standard tank sitting on the workbench and run the line to the carbs. The inline tap is pretty handy when you have to disconnect it all. While I was there they also had clear tubing in various sizes which is great for the float bowl drains and bleeding brakes etc.
Hobbit210
Fri Nov 02, 2012 8:06 am » Post: #11 » Download Post
Go to your local model shop (or on line...or me!) and buy a rc car fuel bottle. I'll put up a picky over the weekend as I'll be using mine.
Mike
TuckerBag
Fri Nov 02, 2012 11:03 am » Post: #12 » Download Post
OK, I'm starting to really 'dig' this thread but seriously know;
Is anything mentioned here going to pull the chicks like an empty mini beer keg?
I'm coming at this from a socially empowering point of view:
Functionality and a certain 'cool' vibe.
I'm talking an iTank with USB connector for YouTube,.... yeah?
nxrsr20
Fri Nov 02, 2012 8:48 pm » Post: #13 » Download Post
How about a NOS bottle? It 'sorted out' a gixxer problem.
Lane
Sat Nov 03, 2012 8:37 am » Post: #14 » Download Post
The problem with most Gixxers is the nut that connects the seat to the handlebars!
pbekkerh
I boughta Sealey tank, no good.
Tue Apr 30, 2013 4:19 pm » Post: #15 » Download Post
I got tired of my homemade tank, so I bought a Sealey tank off Amazon but am very disappointed.
There is no gasket in the lid
When tightening the lid(not very tight) it just jumps off.
The holes for the steel hanger, are drilled right through to the tank, so the gasoline can leak or evaporate through there.
I'm negociating with the dealer right now.
Poul
MC21SE, KISS box
