pgm-11
m8nyloc
pgm-11
Wed Nov 14, 2012 4:49 am » Post: #1 » Download Post
I am trying to update the ignition system on my MC18 (frame number MC18- 1010798) it has the large PGM CDI box with what seems like a plastic cover. Thought I update to a pgm-11 which I have also have the wiring loom for pgm-11. I have notice that the two cables with wires in them from the stator and mag have different plug's than the PGM-11 loom, also different number of terminals in the plugs.
will this mean I have to get a later model Mag and stator.???
Also not too sure on the correct age and model of this bike. if somone can tell me from the frame number that be a great help.
Dmitry
Wed Nov 14, 2012 12:44 pm » Post: #2 » Download Post
88 MC18 has PGM 1
89 MC18 has PGM II (roman 2, not 11)
From what I remember reading it's a bit of a job since you need new stator and flywheel, some modifications required to mount the "mag" as you call it. possibly RC servo?
m8nyloc
Wed Nov 14, 2012 10:52 pm » Post: #3 » Download Post
So Its a 1988 MC18 as the motor came out of a frame the had PGM-CDI,well thats what is embossed on the plastic cover of the ECU, are PGM 1 the same as PGM-CDI.
RC Servo??? whats this?
nxrsr20
Thu Nov 15, 2012 1:26 am » Post: #4 » Download Post
Stick up a photo for all to see and people can confirm what you have.
An rc servo controls your power valves by opening and closing them based on the signal given to it from the pgm.
Dmitry
Thu Nov 15, 2012 3:22 am » Post: #5 » Download Post
The only 2 NSR's I've seen up close are both mine, all the info I got came from this forum, lots of it by simply reading, start here: http://www.nsr250.net/
m8nyloc
Thu Nov 15, 2012 5:20 am » Post: #6 » Download Post
ok so the full story:)
i am putting the motor that came out of a NSR250 frame in a super kart frame, well the motor is aready in the kart frame. The bike frame has PGM-CDI unit with wiring harness and i did not want to use the PGM-CDI or harness, as at a later date I will restore the bike and in the meantime have some fun using my super kart with the NSR motor, is that clear so far?. i managed some time ago to aquire a PGM-II and harness and now relize that the harness wont fit the terminals on the motor. so do I need a stator and pickups to fit the PGM-II?. guess i do.
The RC servo terminals/connectors fit the PGM-11 harness so all good there i guess.
TPS sensor connector is different as is the air balance connector.
I would put up some photos but not figuered out how to do that yet on this site.
Any thoughts everyone Smile
Dmitry
Fri Nov 16, 2012 1:33 pm » Post: #7 » Download Post
From what I remember reading you will have to modify cases to use PGM II stator and pick-ups.
Seems like you will also need to replace solenoids and TPS... would be easier to find another PGM-1 harness or carefully use yours in the cart without hacking it
Fri Nov 16, 2012 9:29 pm » Post: #8 » Download Post
You mean NSR-WORLD.COM, don't you?
Dmitry
Sat Nov 17, 2012 6:16 am » Post: #9 » Download Post
umm yeah, I guess... just hit "HOME" button, copy/pasted the URL, didn't even realize that it wasn't same, bit confusing...
this is where I got 99% of my NSR model info:
http://www.nsr-world.com/history/
Kostas Dee
Sat Nov 17, 2012 8:51 am » Post: #10 » Download Post
Dmitry wrote:From what I remember reading you will have to modify cases to use PGM II stator and pick-ups.
Νot true
You just need the different flywheel along with the different pickups,you said that you got a complete 1989 wiring,are the pickups missing?Also wherever you bought it the seller had to include both solenoids too as long as you have told him about your mod plans.
Addicted to that Rush..
NSR 250 MC18 '88 JHA pipes
NSR 250 MC28 R Tyga pipes
Aprilia RS250 MKII Arrow pipes
Sat Nov 17, 2012 12:57 pm » Post: #11 » Download Post
Kostas, can you change your signature image to a thumbnail please.
Kostas Dee
Sat Nov 17, 2012 7:24 pm » Post: #12 » Download Post
Sure Andy
