The cranks lie on the same axis but they aren't a single crank. If I recall though they did a number with a one piece centre gear making those a single crank.
As a note, I don't ever recall Honda claiming or stating it was a single crank, more the press. _________________ If I have to take the carbs off once more...
I never heard for a single crank on a V4 NSR.
As i know all of them have two cranks with the same design like this in the photos.
A think that i remember and impressed me when i saw it,was that the NSR500 V4 after 1989 models as it is this in the photos has a specific design on the cylinders to prevent more coolant after some problems with the temperatures.
This design almost doubled the coolant amount of the cylinder and the head studs actually been outside of the cylinder.
If you are interesting i may have a drawing of it somewhere in my pc folders,just let me know to search for it.
Yes Stephen as you said pre 90 models had a simmilar design whith mc16-mc18 but they had problems with temperatures and after they made this design with displaced cylinder studs to prevent more coolant.
http://img152.imageshack.us/img152/4600/nsr500v436.jpg
I have also a video with some minutes inside the 1988 HRC production erea with lots of terra (NSR250-NSR500)beauties inside,take a look after 1:14 http://www.youtube.com/watch?v=ldTwmeqEqVQ&feature=relmfu
And at 0:30... You just know Mr. HRC is chuckling inside!
He launches that SEED off the line! Unfortunately it looked like he launched it into the tyres just before the end, too! _________________ Andy.
StephenRC45 wrote:Well, yeah that might of been a little lie.
Ahhhh, it all becomes clear now.
Twin contra-rotating cranks on the YZR500 (also RGV and Cagiva 500's?).
Twin cranks on the NSR rotating in the same direction.
Yep, the NSR500 is a true V4. Not an oblique square 4 with 2 "proper" full width cranks counter rotating to balance the rotational forces like a YZR500.
This is an RD500, but it shows the idea of a twin cranked "V4" (it's not a V is it?) clearly.
_________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
