nsc 250 wrong card
WIRAT
nsc 250 wrong card
Mon Feb 04, 2013 2:57 pm » Post: #1 » Download Post
How can i do to start bike
NSR250 PGM4
2001
Mon Feb 04, 2013 5:54 pm » Post: #2 » Download Post
Hello Wirat, and welcome to the forum.
If you do not have the correct card for your PGM-IV, it may be hard to buy a new one in Thailand. You can try TYGA Performance (based in Sattahip) or Red Baron in BKK.
Maybe it is easier to fit a PGM-III and MC21 wiring harness instead. You may be able to buy it second hand from Red Baron.
WIRAT
Fri Feb 08, 2013 5:55 am » Post: #3 » Download Post
Do u mean can bypass pgmcard
can regenerate old card to new
thanks
Regards
Fri Feb 08, 2013 7:52 pm » Post: #4 » Download Post
I mean remove the PGM-IV and MC28 harness, and replace it with a PGM-III and MC21 harness.
It's not a big job, but you will have to fit the PGM-III under the rear seat, lengthen the wires from the stator (generator) to the main harness, and probably fit some MC21 instruments. (MC28 = digital display, MC21 = mechanical.)
As an additional bonus: A standard MC28 only produces 40hp, but if you fit a PGM-III/harness and do the wire-splice you will get an instant power gain:
  • If everything is standard, and you fit a PGM-III/harness (with wire-splice), you will probably go from 40hp to about 47hp†.
  • If you have already removed the restrictions in the standard exhaust downpipes, then you will probably go from 40hp to about 52hp†.
  • If you already have race exhausts, you will go from 40hp to about 60hp†.
Not only will a PGM-III/harness be cheaper and easier to find than a new PGM-IV card, but you will also get "free" power on top!
Please note that you must check your jetting‡, and should modify the airbox as well as the PGM-III harness to get the best power. There are lots of posts about airbox modification on the forum.
† Approximate rwhp figures.
‡ Please do not discuss specific jetting in the public areas. There is a dedicated Members area for jetting discussion.
