Hi everyone.
JaviNSR
Hi everyone.
Tue Oct 29, 2013 7:27 pm » Post: #1 » Download Post
Hello guys,
I'm Javier from Madrid.pleased to meet you.
I'm proud to say have recently purchased a MC18 form Japan. It's the black with the SEED colours.
I allways loved this bike. I just received the bike today. Smile
The speedo says it has 10k so i have a good premolition with this bike.
The fairings are a bit bronken but the chassis and engine looks real nice.
I'm cheking all the stuff before the first start up oil,spark,gas, battery.
Soon i'll post some photos, i'm repairing the fairings as they almost fall off.
I have to charge the battery it won't start, but i still haven't seen were is it Wink
Any tips to flood the carbs so it starts easily?
bushman
Tue Oct 29, 2013 9:08 pm » Post: #2 » Download Post
Hola,the battery is under the seat,do you know how old that battery is?It might be better to buy a new one,at least you will not get problems later if the one in the bike now is finished!Try using full choke,and no throttle when you start it.Best of luck.
JaviNSR
Wed Oct 30, 2013 7:50 am » Post: #3 » Download Post
Thanks for your reply bushman.
I had 2 stroke bike but not like this one. I was looking for a 500 but it was far away from my budget. Embarassed
I want to check the engine first off all to see what needs to be done and the i'll try to purchase all the stuff at once.
The bike does not have user manual so i have to read the forum to understand the bike.
I've see there is a rotating knob near the choke lever, what's for? for oil supply?
I'm really ansius to go for a ride Evil or Very Mad .
bushman
Wed Oct 30, 2013 8:29 am » Post: #4 » Download Post
That is the idle speed adjuster.
JaviNSR
Wed Oct 30, 2013 8:52 pm » Post: #5 » Download Post
Thanks again, i'm just getting started. Embarassed Embarassed
Today i went for a try as i left charging the battery.
I pulled the choke lever and started by hand until i could smell the gas in the exhaust.
Then I turned the key and started to kick but it didn't start.
I repeated the operation three times without success.
So I took off the lower spark plug and tested the spark and there was also some gas on the plug.
I'm thinking in pouring some gas directly to the carbs with a syringe to help her to get started.
NSR 1 - 0 Me Evil or Very Mad
JaviNSR
Sun Nov 03, 2013 12:42 pm » Post: #6 » Download Post
Hi mates,
I finally could start it, it took hours for the first time but finally pouring some gas directly to the carbs and a feeding bottle.
The tank is a little clogged so it needs some clean.
It would start by hand, but the lever comes back very hard and i almost twist my wrist at first attemp, pitty that the lever is missing teeth.
Razz Razz Razz Razz
I have to change the clucht oil .Wich one you'll recomend please?
Regards,
Javier.
gepe
Sun Nov 03, 2013 7:48 pm » Post: #7 » Download Post
Javier,
I would suggest that you first get the basic information for your bike from various web sites. nsr-world is a great source with loads of info, also Jamie's web site. There is even an MC18 Honda workshop manual as PDF on the web. This saves you from a lot of frustration when no one answers your questions...
gepe.
bushman
Sun Nov 03, 2013 8:59 pm » Post: #8 » Download Post
For the gearbox oil,you can use any good brand,I use Motul Transoil.,use .7 litre.Perhaps remove the carburetors,and clean them,if the bike has been unused for a time,it's advisable.Also check,clean or renew the air filter.New spark plugs will help too.Make sure you use good quality 2T oil always!
JaviNSR
Mon Nov 04, 2013 7:53 am » Post: #9 » Download Post
Hi,
Many thanks for your replies, they are very apreciated.
I didn't wanted to diassembly the whole bike but it seems to be necesary to leave in fair good conditión.
The bike is very good shape but most of the rubber parts needs to be changed.
The bike sounds very good,it has the original exhaust.
I have a few neighbourgs who like old bikes and when i started the bike they sudendly appeared to see what was going on.
They were astonished with the bike, here there are very few of them.
Thanks again i 'll post the process when i get some improvements.
JaviNSR
Tue Nov 05, 2013 12:27 pm » Post: #10 » Download Post
Hi mates,
How can i become supporter?
I want to help this website as it's very complete for our bikes. Also I am needing some tech info to get the bike in good conditions.
Tue Nov 05, 2013 4:38 pm » Post: #11 » Download Post
Hello Javier, and welcome to NSR-WORLD.
Please follow this link to become a Supporting Member.
JaviNSR
Thu Nov 14, 2013 10:39 am » Post: #12 » Download Post
Hi all,
Today i received the welding sticks for the fairing repair and i also purchased a repair kit for the carbs as they seem to leak a little.
I'll do it in the weekend and post some photos of the proccess.
I've seen the carb assembly is like rocket science, i hope i can get it RFT.
Any tips for the carbs will be apreciated.
Regards,
Javi
Sun Nov 17, 2013 11:28 am » Post: #13 » Download Post
JaviNSR wrote:Thanks again, i'm just getting started. Embarassed Embarassed
That'll surely have flooded it, and soaked the spark plugs...
JaviNSR wrote:So I took off the lower spark plug and tested the spark and there was also some gas on the plug.
Yep, thought so!
If you get the plugs wet, the spark will track the fluid, and not jump the gap.
JaviNSR
Tue May 27, 2014 8:49 am » Post: #14 » Download Post
Hi Mates,
Yesterday i had finally my first ride in the R5K after 8 months laying in the garage, as now is road legal.Smile
I have been registering the bike since the purchase in October, but finally is done.
I have installed the oil pump, but for more security i placed a 2% of oil directly to the tank, and now the bike is very smokey.
What's the correct mix %? 2% or 4%?
It's the firts tank i have used after the purchase so i thounght it will be better with extra oil.
It starts at firt kick in the morning after 2 days so i think the engine is in good shape. I went for a 10km trip and the bike feels very nice and sounds superb.
At firts i stalled the bike a few times in first gear till i got the feeling of the clucth and revs but then it was all ok.
I need to check some parts as the fork seals and the front brake pads & rotors. I also need a new rear tyre, this one is new but it has some cracks because of the time, is was manufactured in 2000.
Here's a pick i hope you like it.
bushman
Tue May 27, 2014 1:53 pm » Post: #15 » Download Post
There is no need to add 2T oil to the fuel tank if the oil pump is adjusted correctly and functioning as it should,in fact it is a bad idea!Get a new set of tyres,get out on the road,and enjoy your NSR! Razz
