Rear shock: rebuild or replace ?
rhyshrc
Mon Dec 09, 2013 7:21 pm » Post: #1 » Download Post
The SE/SP rear shock on my mc21 is shot and needs attention ASAP.
I was going to just get it rebuilt, but is there much point? I'm quite a bit heavier then what the shock was designed for @ 90KGS (not to mention way too tall, I look like a clown on the bike Surprised) so once rebuilt it will probably be far too soft ?
I have looked at maxton ohlins etc but I'm not doing anything serious with the bike so can't really justify £800+ for a shock.
Aware of the nitron kit but unfortunately I have reason not to go with one of those.
Any recommendations please ?
Mon Dec 09, 2013 7:33 pm » Post: #2 » Download Post
We've always had the stock shocks rebuilt with good results.
Some require a new spring, I think Penski's springs are the same dimensions.
MEM
Tue Dec 10, 2013 3:18 am » Post: #3 » Download Post
What Stephen said. I purchased an Ohlins shock for my SP, and still had to get a stiffer spring and change the valving and i'm only 140lbs. I also had my stock shock rebuilt on my SE with a new Eibach spring and changed the valving, and it performs wonderfully.
rhyshrc
Tue Dec 10, 2013 10:32 am » Post: #4 » Download Post
Thanks guys!
Stephen: Any recommendations of a suspension shop where you have had good results ? Very Happy
Tue Dec 10, 2013 12:25 pm » Post: #5 » Download Post
K-Tech have always done ours. You have to ask them to replate all the fastening if you want them done.
Tue Dec 10, 2013 1:11 pm » Post: #6 » Download Post
maxton and reactive suspension have been good service when ive used them Very Happy
nikhlitschek
Tue Dec 10, 2013 11:53 pm » Post: #7 » Download Post
someone known how can a I rebuild a mc16 shock?
Chester362
Fri Dec 13, 2013 6:05 pm » Post: #8 » Download Post
Kais in Atherton near Manchester do a good job.
Rebuilt an F3 shock for me a couple of years ago.
Fitted a new aluminium end cap with a valve for the reservoir too.
nine16
Tue Dec 17, 2013 2:59 am » Post: #9 » Download Post
Replaced mine:
geezagillard
Fri Dec 20, 2013 7:04 pm » Post: #10 » Download Post
Nine16 that looks like an Ohlins in an MC18....can you let us know where you sourced?
nine16
Thu Jan 23, 2014 8:14 am » Post: #11 » Download Post
It's the HO206. I believe it's technically for the MC21, but the length in only 5-7mm longer and considering it has adjustable ride height and I've switched to a 17" rear, it should be fine.
