rc valve and starting issue
swerace
Sat May 02, 2015 12:06 pm » Post: #1 » Download Post
I have a weird problem.
My rc servo are on HI all the time. If i turn it to low by my hand it goes to HI when I turn key on. No difference if I pull out tps contact. But, if I kick the bike the servo goes to middle and if I give it full throttle when I kick, it goes to LO!!?? Smile
Bike is hard to run when cold. It starts with choke, but if I give it throttle it sounds like a cow and dies Very Happy If i let it warm up a bit on idle and then raaarly gives it throttle "blipping the throttle" It will run. When its really warmed up its no problem. Just weak in the lower rpm.
Kind regards
Micke
swerace
Sun May 03, 2015 4:25 pm » Post: #2 » Download Post
Have checked my valves. Everything is fine, but my servo goes from Hi to Lo. So if i start the bike it has open valves and if i give throttle it close the valve Question
Sun May 03, 2015 4:31 pm » Post: #3 » Download Post
Has it ever run correctly? Is it the original servo?
swerace
Sun May 03, 2015 5:07 pm » Post: #4 » Download Post
This is my first 2 stroker (road bike) so I don't now if it have run perfect. But it run way better then now. Don't know if its the original servo. Can a fault tps made this problem?
swerace
Sun May 03, 2015 5:47 pm » Post: #5 » Download Post
I found the problem! It wasn't the bike, it was the owner! Embarassed
The tips was in totally wrong position!
Sun May 03, 2015 8:16 pm » Post: #6 » Download Post
Make sure the TPS is set correctly, as even if its position is only slightly out, it can have a huge difference in how the bike performs.
Glad you tracked it down though.
