Correct res hose routing for ohlins shock
drunkn munky
Sat May 30, 2015 6:55 pm » Post: #1 » Download Post
Is this correct to have the res hose exiting at the rear,
Sat May 30, 2015 7:18 pm » Post: #2 » Download Post
That should work OK, but all of the photos Matt sent me while developing it, showed the hose running outside of the frame (for easy removal/installation), so can't say for sure.
Are you going to run an airbox? If not, then I would be inclined to see if it will fit with the reservoir hose at the front, which would allow the reservoir to seat a little closer to the standard position, further along the frame spar.
Sat May 30, 2015 7:20 pm » Post: #3 » Download Post
Mind you, just looking at the photos again, turning the shock won't work, as the hose would be angled the wrong way out of the shock head. Confused
drunkn munky
Sat May 30, 2015 7:46 pm » Post: #4 » Download Post
I did try it the other way but it look totally wrong. I guess the bodywork would cover the hose up if run out side the frame, the hose did feel quite forced running it as i have in the photo's.
Not thought about weather to run a airbox or not yet, it'll spend most its life on the track but i had a stock setup in mind if just for ease of use and maybe change it later on. Im also still running stock pipes albeit with tyga cans so there possibly the weakest link and need upgrading first.
Sat May 30, 2015 8:38 pm » Post: #5 » Download Post
It does look wrong, but there's not much you can do really. With the outlet on the shock head as it is, it looks like it could do with a 20~45° banjo to angle the hose more "forward", and similar on the reservoir, where the banjo could do with rotating "inboard" more. These two changes would give the hose an easier run.
To me, the hose itself actually looks too long to run inside the frame. I would expect it to be about 300~320mm (stock MC21 is 285mm, with the outlet on the side of the shock). If it's any longer, I would personally assume that it's not been designed to run within the frame constraints.
drunkn munky
Sun May 31, 2015 5:41 am » Post: #6 » Download Post
It definitely feels like some adjustments are needed, not what i expected from a new shock designed for the bike
Mon Jun 01, 2015 1:36 am » Post: #7 » Download Post
Question: Is the reservoir bracket bolted to the correct mount on the frame?
<edit>
This just in from Matt@TYGA...
drunkn munky
Mon Jun 01, 2015 6:11 am » Post: #8 » Download Post
That does look further forward than mine but im certain i used the front 2 holes rather than the rear 2, will check later
drunkn munky
Thu Jun 04, 2015 8:28 am » Post: #9 » Download Post
Right holes, bracket wrong way round Embarassed
Thu Jun 04, 2015 12:28 pm » Post: #10 » Download Post
Ahh, good stuff!
Nice bodywork, by the way! Wink
Thu Jun 04, 2015 2:07 pm » Post: #11 » Download Post
yes loving the green Very Happy
Thu Jun 04, 2015 9:03 pm » Post: #12 » Download Post
It's a very nice set of bodywork, Si, and no screen will do it justice!
I hope you can make it to Donington, DM! Would be great to see you and the bike there, even if it's just to show off and hurt everyone's eyes! Laughing
drunkn munky
Fri Jun 05, 2015 8:48 am » Post: #13 » Download Post
Very Happy It is rather bright, but not green!!!!
I may make donington it all depends on what horrors the motor holds for me, i could always have someone push me up and down the paddock whilst making brum brum noises. You could join me Si Laughing
Yuri
Fri Jun 05, 2015 11:53 am » Post: #14 » Download Post
With that color the drunkn munky's can still find the bike after lots of drinks
Mon Jun 08, 2015 12:01 pm » Post: #15 » Download Post
yes count me in Laughing
