so i take m mc21 out today and it just seemed out o tune then when i get to 10000 rpm it flat lined straight away i thought dam power valves i only just adjusted them last week so thought i may have forgot to tighten the lock nuts but when i check them its all good so i then check the alignment marks and find the servo is not moving at all at any condition so i switch her off and move the servo by hand then start her up and the servo returns and starts working normal again all adjustment is still correct so i thrash it for most of the morning and it runs fine .
then after a quick feed and piss stop of about half hour i fire her up and as soon as i hit band in first i can tell the power valves are not working again.
has anyone seen this before or got any ideas why it would cut out intermitantly like that
cheers for the help
"Batmans a scientist"
