MC28 Oil Pump Alignment Marks/Quick Turn Throttle
Dana
Sun Sep 04, 2011 6:31 am » Post: #1 » Download Post
As I've figured out I have a quick turn throttle on the bike, I was curious if this had any impact on the oil pump. There wasn't much info on the matter when I searched (or I was using the wrong search words), but some seemed to think it was OK and others said not OK.
I've experimented and have concluded that running a quick turn shouldn't matter, since the oil pump cable is connected to the carb end (buttery valve for a lack of another name to call it). The throttle cable still moves the same distance as a stock setup would.
Anywho, I've adjusted the oil pump cable so that with 1/2 throttle, the first alignment mark lines up. But should the second mark line up at WFO (wide F-in open)? I plan on going really fast (lmao) and want to make sure I don't grenade it the first time out. Is it better to give it more oil than less for going fast in higher rpms?
Thanks!
Dana
2016 Husqvarna 701SM
2021 Husqvarna FS450 supermoto
1995 NSR250r MC28
pvan340
Sun Sep 04, 2011 9:41 am » Post: #2 » Download Post
http://tech.nsr-world.com/nsr/nsr-all/oil-pump/
Should help. The beauty of running the oil pump is when you snap the throttle shut from a wide open run, (about 300m to early if your me!) it's still pumping oil even at closed thottle.
Dana
Sun Sep 04, 2011 10:47 am » Post: #3 » Download Post
Good find.
So full throttle is the adjustment I go with then. I wonder if I'll have to adjust it to the point it's open even at idle...?
Thanks pvan!
Dana
1995 NSR250r MC28
Sun Sep 04, 2011 12:40 pm » Post: #4 » Download Post
It won't change a thing, the oil pump position is taken from the carbs, not the throttle directly.
Sun Sep 04, 2011 4:36 pm » Post: #5 » Download Post
You have to watch those buttery valves though! Smile
Mon Sep 05, 2011 6:41 am » Post: #6 » Download Post
pvan340 wrote:http://tech.nsr-world.com/nsr/nsr-all/oil-pump/
Have you actually watched an oil pump pump oil in the closed thottle position?
And you still get e small supply of oil when you "snap the throttle shut" on premix as even if the throttle is shut the butterflys never are (if they were the bike wouldn't tick over and would stall if you closed the throttle and dipped the clutch).
pvan340
Mon Sep 05, 2011 9:12 am » Post: #7 » Download Post
True, true. Very Happy
Run my road bike with the oil pump, the track bike is on premix. Neither has given me any problems.
