Long term goals
Yuri
Long term goals
Tue Mar 10, 2015 5:24 pm » Post: #1 » Download Post
I am thinking of buying pipes
My long therm goals will be to put a mc21 hrc tt-f3 motor in a mc28
Is it possoble to use a mc28 rotor on a hrc motor ? If it is not can you change the crank web on that side to take the mc28 rotor
Will the best pipes for a tt-f3 motor be RS250 nf5 pipes with jha flanges ... ?
Tue Mar 10, 2015 8:48 pm » Post: #2 » Download Post
The simple answer to both of those, is no.
The easiest to explain are the pipes. Just get some NSR250 pipes. TYGAs would be the easiest option, if you want new, and certainly the best performance-per-pound/dollar/baht/sheckle or whatever other currency you may work in!
The best NSR we've ever run was using DogFights. You can still get them new from Japan, but you really have to pay through the nose for the pleasure, especially if you want stainless/carbon. There are several kinds of Jha pipe... some work better than others, and the differences are quite striking! Once upon a time, I would've sworn by them, but not after 1000s of dyno runs over the last 10 years.
As for the rotor, you'll need to look into that once you really know what you are doing with the motor. IF you find a good HRC crank, then no, an MC28 rotor (of any description, including an HRC one) will not fit. Yes, you could in theory butcher an HRC crank to fit a stock flywheel to it.
Yuri
Wed Mar 11, 2015 6:07 am » Post: #3 » Download Post
Then I will get the dog fighter pipes
Yuri
Wed Mar 11, 2015 9:25 am » Post: #4 » Download Post
Was it the old or new design dog fighter pipes ?
Wed Mar 11, 2015 9:54 pm » Post: #5 » Download Post
Those Dog Fights came from way way back. I wouldn't be surprised if they were from the mid 90s. They ran 90-91 spec HRC silencers too.
Remember though, what suits one bike may not necessarily suit another. Different pipe characteristics also suit different conditions, tunes, and/or requirements. It's not as simple as just saying "Dog Fights are the best [on a tuned TT-FIII MC21]", and then fitting them blindly to an SP spec MC28 and expecting the best performance.
It's commendable you buying all the "right" parts before even getting the bike, but sometimes things just need to be tested, tweaked, and even discarded and replaced, before you hit the sweet spot.
Yuri
Thu Mar 12, 2015 7:37 am » Post: #6 » Download Post
I understan that the dogfighters are not the best on a SP motor . It is just easier to buy once for the end result
Thu Mar 12, 2015 1:16 pm » Post: #7 » Download Post
dog fights work very well on mine
Yuri
Thu Mar 12, 2015 1:40 pm » Post: #8 » Download Post
silikesguiness wrote:dog fights work very well on mine
Are you using the old or the new type .
Thu Mar 12, 2015 1:51 pm » Post: #9 » Download Post
That's not what I said, or meant to say, if that's how it sounded, Yuri.
The Dog Fights may not be the best option for YOUR particular setup. What I said was they performed very well on the heavily modified MC21 TT-FIII of StephenRC45's.
Given the chance, we will run several different sets of pipes if we can, and use the ones that give the most desired performance.
In all honesty, I doubt when the difference between TYGAs, Dog Fights, Ethos, HARC Pro, i-Factory, or even most Jha's will be of any consequence to you.
Yours is finally running now then, is it Si? What does it handle like with those forks?
Thu Mar 12, 2015 1:58 pm » Post: #10 » Download Post
the big fat expansion chamber versions Laughing ive had 2 sets and they were very different to look at and my first set (i still run) worked better,bikes not ready for action just yet andy,ive been chasing a rear marchesini for over a month and been messed about quite alot Rolling Eyes so sent the rear magtek off to be refurbished,ive waited a while as i couldnt afford both Rolling Eyes
Yuri
Thu Mar 12, 2015 2:15 pm » Post: #11 » Download Post
silikesguiness wrote:the big fat expansion chamber versions Laughing ive had 2 sets and they were very different to look at and my first set (i still run) worked better,bikes not ready for action just yet andy,ive been chasing a rear marchesini for over a month and been messed about quite alot Rolling Eyes so sent the rear magtek off to be refurbished,ive waited a while as i couldnt afford both Rolling Eyes
The thin one is the old type it was made before 2000
So that must be what is on the TT-F3 ...
Thu Mar 12, 2015 2:21 pm » Post: #12 » Download Post
sorry to clog your thread up,you can see the the differences between the dogfight chambers in this pic,the blue canned bike has the best pipes
Yuri
Thu Mar 12, 2015 2:44 pm » Post: #13 » Download Post
I have also found this photo
