hi all,my mc18 all seems to be fine,with this new motor,but i have noticed the slow speed gear changes are abit cloncky/nocky,when i put it in first it seems to nock,and most slow speed gear changes 0-40mph are nocky,my old cbr400rr used to be the same and would get worse as the chain stretched,i am using a 10-40 semi putoline 4 stroke gearbox oil as that is what my local shop have suggested,,,,they said it would be fine and any fully synthetic would cause clutch slip,do i need a 2 stroke gearbox oil,or do you think its some thing else,the bike rides fine but i dont like this nock, the clutch leaver is adjusted so it has 1cm of free play,and this motor has a standerd wet clutch set up,i can get silkoline oil but am not sure what is the best one,,
NSR250 MC18
