NSR250 MC18 R5K Engine Rebuild
Page 1 of 4  Goto page 1, 2, 3, 4  Next Download Topic
philup_7@hotmail.com
Mon Mar 09, 2026 3:08 pm » Post: #1 » Download Post
Hi All
It has been a fair while since I last wrote on the Forum due to various reasons (getting older is top of the list lol), but also been fairly busy sorting & rebuilding my son Chris’s NSR250 MC18 R5K with him.
But, before I start, can I thank all those on the NSR WORLD Forum (you all know who you are) for all their help & pointing me and Chris in the right direction as none of the following would have been possible, not forgetting all the invaluable information on the NSR WORLD site itself, especially the engine rebuild procedure https://archive.nsr-world.com/.
Our first attempt was to fit a used MC28 Engine to the MC18 which looked in reasonable enough condition to do. However, fitting the MC28 Engine into the MC18 threw up a number of issues, and items to be purchased, that although have been previously documented I guess it’s not till you try & do it you just don’t realise!
The issues & items required as follows:
    (1) New/Used MC21 PROTEC GPS-01 Gear Position Sensor Product 11609 or MC28 Change Switch (MC18 Neutral Switch is not only completely different, it is also in a different position on the Crankcase to the MC21/28 & operates in a totally different way. Additionally, Neutral switch re-wiring is required, but this is not much of an issue.
    (2) Used MC28 2T Oil Pump as one didn’t come with the Engine (MC28 2T Oil Pump has an additional Oil Way to the MC18);
    (3) New DMR-JAPAN Dry Clutch Collars/Spacers (Original Spacers had worn so bad the Clutch didn’t work at all);
    (4) New DMR-JAPAN MC28 Water Pump, TYGA & DOGFIGHT RACING also supply their own one as well (The issue with the Water Pump arose when sorting the Clutch issue above out);
    (5) New DMR-JAPAN Wide RC Valve Pulley Type2 with a wide Pulley & over-torque release mechanism (Our attempt to get the MC28 RC Valves to mate as best as you can with the MC18’s PGM II).
NOTE: More detail of these issues above will be dealt with as I continue to add to this topic in the coming weeks.
Most of the parts above were obtained via: WEBIKE JAPAN, AMAZON JAPAN, JAUCE JAPAN & Jap4 UK Ltd.
After riding the NSR250 for a little while, the MC28 Engine decided to be near impossible to start, so a re-think led to a total rebuild of an Engine for the MC18 R5K as follows.
Rebuilding the MC18 consisted of using the MC28 Crankcase, new or rebuilt MC28 Crankshaft with the MC18’s Cylinders (Nikasil plating by Langcourt, Weston-Super-Mare, UK), original Cylinder Heads, Stator & Pick-ups.
Detailed instructions on the complete Engine strip and rebuild are on the NSR WORLD site which I found extremely useful and as you will see a great deal of similarity. The MC28 Engine was removed for cleaning prior to dismantling & all parts open to any ingress were taped off and sealed.
Last edited by philup_7@hotmail.com on Fri Mar 20, 2026 3:23 pm; edited 6 times in total
Mon Mar 09, 2026 3:12 pm » Post: #2 » Download Post
MC28 2T Oil Pump
Although the MC28 2T Oil Pump was removed prior to the Engine removal, I’ve included a Picture detailing the additional Oil Way that isn't present on the MC18.
Last edited by philup_7@hotmail.com on Tue Mar 10, 2026 10:28 am; edited 3 times in total
Mon Mar 09, 2026 3:46 pm » Post: #3 » Download Post
Dry Clutch Removal
Remove of the outer Dry Clutch Cover to reveal the Dry Clutch Pressure Plate.
Undo (in a crisscross pattern 2-3 steps) & remove the 5 Bolts, 5 Clutch Pressure Plate Springs & Pressure Plate to reveal the Lock Nut.
Remove the Clutch Lifter piece (in the centre) & unstake the Lock Nut with a small Screwdriver lightly tapping it with a Hammer, then undo the Lock Nut using an appropriately sized impact Socket & Cordless Impact Driver (the Lock Nut came off fairly easily, which is unusual for me).
The Lock Nut, Thrust Washer, Clutch Plates & Clutch Inner Basket/Drum can now be removed.
Undo the 6 Bolts holding the Clutch Outer Basket & remove the Basket.
Last edited by philup_7@hotmail.com on Tue Mar 10, 2026 11:31 am; edited 4 times in total
Mon Mar 09, 2026 3:53 pm » Post: #4 » Download Post
Dry Clutch Housing Removal
Righthand Crankcase Cover Bolts removed revealing the new DMR-JAPAN Water Pump from WEBIKE JAPAN previously installed due to the old Plastic drive gear cracking (not surprising given its age, bit like me really).
The MC28 Water Pump differs to the MC18/21 regarding the number of teeth on its drive gear, MC28 has 25 teeth and the MC18/21 has 26 teeth so made sure I got the correct pump. The one I chose was Product E4-28005 from WEBIKE JAPAN as it came with the Seals & Gaskets, although it is also available as separates’.
General Components under the Dry Clutch Housing Cover.
Last edited by philup_7@hotmail.com on Wed Mar 11, 2026 12:33 pm; edited 3 times in total
Mon Mar 09, 2026 4:04 pm » Post: #5 » Download Post
Flywheel Removal
Using a Flywheel Puller tool (TYGA TYTO-0014), 19mm Ring Spanner & Adjustable Spanner the next job was to remove the Flywheel Bolt & Flywheel, which to my surprise came off very easily (have had very bad experiences with Flywheels in the past mostly to do with cars though lol!).
Last edited by philup_7@hotmail.com on Tue Mar 10, 2026 11:35 am; edited 1 time in total
ericandchi
Mon Mar 09, 2026 10:08 pm » Post: #6 » Download Post
Great pics and annotations. This will be very helpful to others in the future.
Tue Mar 10, 2026 7:44 am » Post: #7 » Download Post
Great work, Phil!
A little feedback on the annotations. Some, particularly the red & green, do not really have good contrast. I can imagine them being difficult to read for some; especially non English speakers who may try to use Google Lens or similar on the images.
I think it would be better to either have white text on a back background, or black on white, and maintain a consistent look.
For example:
I appreciate you may not have/want to spend the time fiddling around with background boxes, and sincerely appreciate the effort going into the thread. Just some feedback for you.
NSR250 MC18 Rebuild
Tue Mar 10, 2026 10:50 am » Post: #8 » Download Post
ericandchi
Many thanks anything to help such a great forum as we have so much help in the past.
This and I have say totally honestly has to be one of, if not, the best forums out there.
Regards
Phil
Tue Mar 10, 2026 12:17 pm » Post: #9 » Download Post
Cleaning Carb Insulator Mating Surface
Following NSR WORLD’s advice the Carb Insulator mating surface was very carefully & painstakingly cleaned using a new & resharpened (using a Whetstone) Stanley Blade at a shallow angle.
Tue Mar 10, 2026 12:48 pm » Post: #10 » Download Post
Primary Drive Gear Removal
This to be done in two stages, initially, using DMR-JAPAN Primary Gear Holder TL006 ( 2 Bolts securing it to the Crankcase ) to lock the Primary Drive Gear & undo its Bolt.
However, leave the Gear in place for the time being as it makes it a little easier to rotate the Crankshaft and get the Pistons in the right place to remove later on, unless of course you have removed the Cylinders beforehand.
The Clutch Primary Drive Gear was removed a little later on (not in these Images) and also the Kick Start Mechanism was removed before it fell out!!
Last edited by philup_7@hotmail.com on Wed Mar 18, 2026 10:29 am; edited 1 time in total
Tue Mar 10, 2026 2:58 pm » Post: #11 » Download Post
RC Valves Removal
Removed the RC valves while in situ to make like easier (If that ever happens!!).
The Cylinder & Cylinder Head Nuts were slackened off prior to RC Valve removal, you don’t need to do it this way round, just wanted to try out T2Racing special Cylinder Nut Tool to see if it worked without any issues LOL.
Probably didn't need to use the special Cylinder Nut Tool if I took the RC Valves out beforehand, but most probably will need during assembly as it's easier (well I think it is) to assemble the RC Valves whilst the Cylinder is on the Bench (well that's my excuse m'lud).
The RC Valves were sprayed with some KROIL penetrating oil thru the Exhaust Port and left overnight with the hope it would help the extraction process. However, it was still a struggle extracting the RC Valves as the Seals & ‘C’ Clips refused to budge & had to be extracted separately afterwards with my trusty Seal Remover Tool.
Last edited by philup_7@hotmail.com on Wed Mar 18, 2026 10:44 am; edited 1 time in total
Mon Mar 16, 2026 4:47 pm » Post: #12 » Download Post
Gearbox Cassette Removal
Remove 2 Bolts holding the Seal Plate in front of the Cassette Gearbox & the 3 Hex Socket Screws holding the Transmission Oil Pump. Some heat (eg hot Air Gun) may need to be applied on the Transmission Oil Pump Hex Socket Screws as they have a Locking Agent on the threads.
(Note: (1) The Lower Screw is slightly shorter that the other 2. (2) There are 2 'O' Rings which will require replacing. (3) Do not lose the 2 Knock Pins used to locate the Transmission Oil Pump).
If you are not going to replace the Gearbox Output Oil Seal, wrap the Output Shaft with something like PTFE Tape, Cling Film etc.. to help protect the Seal when the Cassette Gearbox is removed.
Now remove the 6 Flange Bolts in a Crisscross pattern 2-3 steps & the Cassette Gearbox together with the Gear Change Spindle should just pull out easily.
This is the point when I should have realised WHY the Neutral Light wouldn’t work (and never would have worked either). It wasn’t just the Gear Position Sensor (GPS) playing up, the end of the Gear Change Spindle was of the MC18 family & not MC21/28 (See 2nd image above).
Another big clue, when the Cassette Gearbox was out, was the lack of a slot in the end of the Drum Selector which the GPS slots into to give the position of the MC21 Gears & Neutral position for the MC28 (See image of MC21 GPS & MC28).
You can clearly see the difference between the ends of the MC28 (previous post) & this MC18 Drum Selector & why the Gear Position Sensor (GPS) just can't work.
Note: I will put some images on the difference between the MC18 & MC21/28 Switch posistions in the Crankcase later on.
Last edited by philup_7@hotmail.com on Fri Mar 20, 2026 3:33 pm; edited 3 times in total
Tue Mar 17, 2026 7:42 pm » Post: #13 » Download Post
Super content, Phil. Thank you.
Annotations look great, too!
Tue Mar 17, 2026 11:08 pm » Post: #14 » Download Post
Hi Andy
Many thanks for that much appreciated.
Phil
Wed Mar 18, 2026 10:14 am » Post: #15 » Download Post
Remove Cylinder Head and Barrels
Remove the 4 Cylinder Nuts & tap Cylinder Barrel lightly with Rubber Mallet or something similar to dislodge it from the seal with the Crankcase.
Rotate Crankshaft to push Piston to TDC and pull Cylinder Barrel (Rear Cylinder in image) upwards away from the Crankcase (support the Conrod by wrapping some Rag around it, yes I know, as you can see I didn’t!!) and away from the Piston.
Cylinder removed to reveal a moon landscape on Piston, something has gone terrible wrong in this Engine, no wonders it didn’t want to start very well!
Repeat above process on Front Cylinder. As you can see the Crankcase sits quite steadily in a vertical position.
The Cylinder Head nuts were slackened off beforehand so they can now be undone and the Heads removed. I didn’t bother removing the Heads as I was going to use MC18 Cylinder Barrels & Heads, although looking down the REAR Barrel revealed the Head was in a bit of a sorry state.
Last edited by philup_7@hotmail.com on Fri Mar 20, 2026 3:34 pm; edited 3 times in total
