lower cylinder
lilblakcooper
lower cylinder
Mon Jul 31, 2006 7:00 am » Post: #1 » Download Post
can anyone help me i need a lower cylinder as ive just noticed that my basket case of a bike has one of the exhaust mounting studs snapped off at the flange when i say stud i mean stud threads and part of the exhaust manifold missing.
rc46
Mon Jul 31, 2006 7:29 am » Post: #2 » Download Post
Depends on how much you want to spend, someone here may have one, but Paul and Matt definatly do
http://tyga-performance.com/site/index.php?cPath=72_79_126&osCsid=068d4217fbcecb59cda999b2dcae9fd9
worth a try
lilblakcooper
Mon Jul 31, 2006 1:08 pm » Post: #3 » Download Post
being new to this forum i have yet to find out who people are so if one of the above people with a spare lower cylinder for an mc16 would like to pm me with details if they want to sell me one.
thanks
rc46
Mon Jul 31, 2006 1:20 pm » Post: #4 » Download Post
Ah Sorry, Paul and Matt run Tyga (see link above) in Thailand and have most of your NSR needs, However, i should have asked what model it was, being a 16 it might prove a bit more difficult to track down, But its worth Emailing Matt (Matt@TYGA user id here) or give the Admin (Andy) a buzz, they may have some sitting around..or direct you in the right direction.
Chester362
Mon Jul 31, 2006 8:16 pm » Post: #5 » Download Post
If it was me I`d get it ally tig welded by a good welder.
You can dress it up after & drill & tap a new hole.
Hell of a lot cheaper than a new/ s/h barrel.
I`ve got a spare barrel I got with my bike that someone butchered trying to drill out a snapped exhaust stud. I`m going to have the same thing done to it.
pbekkerh
Wed Aug 30, 2006 1:53 pm » Post: #6 » Download Post
Did you get it done ?
What were the results ?
How was it done?
I have tried, but in this mechanically undeveloped country I couldn't find anyone who could remove a broken top stud.
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
Chester362
Wed Aug 30, 2006 6:13 pm » Post: #7 » Download Post
How was it done?
I haven`t had this barrel done yet. I`ve had good results in the past.
Whoever drilled the broken stud in my spare barrel let the drill wander. So they just stuck a bolt through at an angle.
I managed to get the bit of the stud out that was left. So now I`m going to get the hole welded up & drill a new hole & tap a new thread.
In the past I`ve drilled out broken studs. Then cleaned out the hole with a tap. Have to drill it centrally.
If you`re not happy with the fit of the new stud after this you can fit a helicoil insert, you can buy kits in different sizes. You then drill the hole out larger than the original size. Use the special tap to cut a new thread. Then screw in the spring-like insert with the key which brings back the thread to the original size. You are left with a more hardwearing steel thread to fit the new stud to then.
Another method is spark errosion by a specialist.
I would`ve thought you should be able to find somewhere in Denmark to get one of these types of repair done?
mick
Wed Aug 30, 2006 6:40 pm » Post: #8 » Download Post
I have a cylinder but it would need a rebore and replate.
