mc16/300
beakergixer750cc
mc16/300
Sun Jan 27, 2008 5:23 pm » Post: #1 » Download Post
Well Andy and stephen i finally got my engine in Very Happy
As with any rebuild there are a number of small problems,first is the powervalve cables supplied,they seem to be a bit long and will be at the limit of their adjustment,are there any slightly shorter cables available?
Also because you guys built it for me i have no information on spark plugs needed or carb jetting recomendations any advice her would be appreciated,i got mc21 carbs with hrc jet kit,hrc stuffers and my powerjets are blocked off.
My mc18Tyga exhausts fitted fine apart from the mounting hole not lining up where it bolt onto the frame,this will be sorted at work tomorrow along with can hanger brackets.
Then i'll get around to finish fabricating my alloy subframe so i can fit my f3 seat unit again supplied by you Laughing
cheers Rob.
Sun Jan 27, 2008 6:17 pm » Post: #2 » Download Post
"Sling the biggest jets you can find in it!", I imagine Steve will say! Laughing
The RC Valve cables thing is probably because of the unique servo arrangement on the MC16. Someone posted a link recently for a company that makes custom cables, I'll see if I can find it... unless Fontyyy beats me too it!
richie
Sun Jan 27, 2008 6:34 pm » Post: #3 » Download Post
http://www.venhill.co.uk/ for custom cables, good company.
cheers
richie
beakergixer750cc
Mon Jan 28, 2008 7:02 pm » Post: #4 » Download Post
In what way is the mc16 servo arrangement unique Andy?
Thanks Richie i'll contact them when i work out what i need.
cheers Rob
Mon Jan 28, 2008 8:08 pm » Post: #5 » Download Post
It operates backwards - the opposite direction to all the other models! The position of it is slightly different too, but I'm not sure if that would effect the length of the cables.
mick
Mon Jan 28, 2008 8:54 pm » Post: #6 » Download Post
Andy wrote:"Sling the biggest jets you can find in it!", I imagine Steve will say! Laughing
If you want it to bog. Laughing
Scary as it sounds I'm running the smallest jets supplied in the HRC kit on mine with open carbs.
I will confirm the point Andy makes all the time that every motor is different as mine hasnt seized yet and still feels fluffy on 165's if I remember correctly.
I really do need to get it on a dyno once I've found my key's. Embarassed
Tue Jan 29, 2008 12:03 am » Post: #7 » Download Post
Is yours a 300 now Mick?
maxim
Wed Jan 30, 2008 4:42 pm » Post: #8 » Download Post
I'd start with a B needle on the middle groove, 185/188 mains, and a 42 slow jet. Then take it to a dyno and check it's in the ball park and work from there. That """"""""""SHOULD"""""""""" be fairly rich, but every engine is different so don't hold me responsible.
Wed Jan 30, 2008 4:54 pm » Post: #9 » Download Post
To be honest I would start with the biggest you can lay your hands on. I made some 240's if you need them lol.
Just work you way down untill it starts to rev then start playing with the needle.
beakergixer750cc
Wed Jan 30, 2008 7:39 pm » Post: #10 » Download Post
[quote="mick"][quote="Andy"]"Sling the biggest jets you can find in it!", I imagine Steve will say! Laughing
[/quot
I used 175's when it was only a little 250 Wink ,now it's a big 300, Twisted Evil i'll stick in me 195's and see how it runs.
What about running it and heat cycles etc etc?
cheers Rob
