Well Andy and stephen i finally got my engine in
As with any rebuild there are a number of small problems,first is the powervalve cables supplied,they seem to be a bit long and will be at the limit of their adjustment,are there any slightly shorter cables available?
Also because you guys built it for me i have no information on spark plugs needed or carb jetting recomendations any advice her would be appreciated,i got mc21 carbs with hrc jet kit,hrc stuffers and my powerjets are blocked off.
My mc18Tyga exhausts fitted fine apart from the mounting hole not lining up where it bolt onto the frame,this will be sorted at work tomorrow along with can hanger brackets.
Then i'll get around to finish fabricating my alloy subframe so i can fit my f3 seat unit again supplied by you
cheers Rob.
