When you say never, how long do you mean? 30,000 kilometers? Less? If you mean that, then your probably on track.
Start with assembly. Make sure the engine components are all in new condition, seals are all good and your work areas and parts are spotless. Build the engine to spec. Proper torque, proper procedure, use good amount of oil on all moving parts. Adjust the oil pump to spec, use good quality oil, set jetting to spec, use good air filter, replace on a regular basis. Use high quality gear oil, etc., etc.
When you go for a ride, let the bike warm up, don't start it and wring it's neck.
That should get you a good high mileage bike without doing bottom ends till 30,000 kilometers.
Oh, don't try to do top speed long straight runs against R1's _________________ Charles Gallant
There's nothing wrong with the English... it's better than many of the native speakers here! It's the "I want to be sure I ll never have to face a an engine failure" part I'm laughing at!
And we had some sun only the other day I'll have you know! Admittedly, it was only about 11 degrees, but after the snow and sub-zero temps for the last month it felt quite spring-like! _________________ Andy.
Build it like Honda did, and run it according to their requirements. _________________ MC21SP Plaything
I am an NSR owner since 2005 and since then I ve never had a "proper" one.
Always something was about to go wrong (and sure enough, many times it did).
I was always left with a far less than perfect bike. So I never got to enjoy it.
Putting these days behind me now, I must assemble a reliable bike (bikes to be exact)
So Yes engine failure is unacceptable for me. Once I get it on the road I want 100% reliability, this is the only way to enjoy a bike, for me any way.
Dave my intetntion is to stick to the way Honda didi it, but what does it take to do something like this?
When you rebuild a bike which was sitting on the side of the road for some years, you can't tell how far you have to go, as far as replacing parts is concerned.
Like I said in a previous post, what do you do?
Do you clean your oilpump, prep it and off you go?
Do you rebuild it?
Do you buy a new one?
(Just an example)
So it isn't as simple as it seems initially....
p.s. Andy you must create a rule for extra poser points for those who have the complete NSR lineup....
