Between the rotor button and fork leg there is about 4mm gap
and on the right hand side
about half a mm gap
Whereas the wet wheel, which is an mc21 rim is pretty much central with around 2mm of gap between the disk button and fork leg.
On the magtek there is 15mm(r/h) and 4mm(l/h) distance from the bearing face to the disk outer face, and 13mm (r/h) and 6mm (l/h) on the mc21 wheel.
So are the spacers between the two models different sizes or is there something more sinister going on? The dust seals dont seem to fit right and all bearings are sat in their correct seats.
Any help would be great..
Paul
