Chain Link Friction
Kubira
Chain Link Friction
Tue Apr 27, 2010 7:48 am » Post: #1 » Download Post
Chain in question is a DID 520, o - ring im pretty sure.
Just wondering about friction between the links. I had the wheel off so i was able to have a geez at the chain. Twisting the links seems to have considerable amount of friction. They dont feel gunked up or anything, just tight, if they werent being stretched around the 2 sprockets they really would'nt like to straiten out at all
Is there any ways to minimise friction like my old bmx bike chains Question
nsrdownunder
1993 Honda nsr 250 mc21 sp
Tue Apr 27, 2010 8:25 am » Post: #2 » Download Post
Yeh it is o-ring . They do take a bit of power to run them but they are low maintanance long lasting. You can buy a non o-ring chain and gain a bit of power more chain lube more replacement but they are cheaper.
Tue Apr 27, 2010 8:38 am » Post: #3 » Download Post
You're feeling the rubber O rings binding slightly on the steel links. So long as it's well lubricated then that's as good as it gets.
A lightweight racing chain absorbs far less power, but doesn't last as long - like 500 miles and it's severly stretched.
Kubira
Tue Apr 27, 2010 9:39 am » Post: #4 » Download Post
Ok, sounds like a plan. Under riding conditions i'd imagine it would loosen up as it heats up anyways.
Deon
1990 Honda NSR250 MC21
Tue Apr 27, 2010 10:15 am » Post: #5 » Download Post
Kubira wrote:Ok, sounds like a plan. Under riding conditions i'd imagine it would loosen up as it heats up anyways.
A man with a white coat once tested a bike's power with an o-ring chain and then with a standard chain. The standard chained test made more horsepower than the o-ring chained test. When the o-ring chain heated up, there was an increase in horsepower. When the standard chain got hot it made less horsepower than the hot o-ring chain.
