MC28 steering lock removal - An answer
caffeinejoe90
Mon Jul 05, 2010 3:54 am » Post: #1 » Download Post
Rebuilding my lemon fresh MC28 and keen to remove the steering lock whilst I'm 'in there'.
I have remove the three retaining bolts and it's loose but won't come free.
Any advise appreciated...
Thanks
Stop sniffing my ring
MC28SP
KLX110 hotrod
CAG Minimoto
1997 WRX
21 Speed Bike
162 Smurfs
Last edited by caffeinejoe90 on Tue Jul 13, 2010 12:08 pm; edited 2 times in total
Mon Jul 05, 2010 4:14 am » Post: #2 » Download Post
You need to drop the lower triple/stem out. There's a reinforced loop around it, attached to the locking mechanism.
caffeinejoe90
Mon Jul 05, 2010 5:26 am » Post: #3 » Download Post
Thanks Andy, Was afraid you would say that!
Good excuse for new bearings tho...
MC28SP
KLX110 hotrod
CAG Minimoto
1997 WRX
21 Speed Bike
162 Smurfs
caffeinejoe90
Fri Jul 09, 2010 2:00 am » Post: #4 » Download Post
Three more questions:
When I reassemble the bike will it be 'confused' now that the lock is removed/unplugged?
If so how do I trick the bike into thinking all is ok?
And finally, does anyone have a template for a blanking plate for the massive hole left by it's removal? I don't want crap to get into the bearings.
Thanks to anyone who can help.
MC28SP
KLX110 hotrod
CAG Minimoto
1997 WRX
21 Speed Bike
162 Smurfs
Fri Jul 09, 2010 5:24 pm » Post: #5 » Download Post
It'll be fine without the steering lock plug.
As for a blanking template, surely you have one, it's called the steering lock...draw round that
caffeinejoe90
Fri Jul 09, 2010 11:52 pm » Post: #6 » Download Post
Thanks fontyyy
MC28SP
KLX110 hotrod
CAG Minimoto
1997 WRX
21 Speed Bike
162 Smurfs
caffeinejoe90
Tue Jul 13, 2010 12:32 pm » Post: #7 » Download Post
Ok, here is a proceedure that will work and allow your street MC28 to function as per normal:
Yes it weighs a ton and you will notice a difference with it removed.
Disconnect the battery as a precaution, pop the tank off and unplug the electrical connectors in the black plastic box that is part of the power valve servo motor assembly.
Undo the PV pulley and put to one side. Undo the servo motor tray and remove. Undo the main oil resivior tank but do not remove as you should have access to the three bolts with a standard allen key. Remove the three steering lock retaining bolts and then the fun begins!
Take off your top tripple clamp and drop the whole front end about 75mm and the lock will come free. I strung my bike from the roof and lifted the chassis. There was not need to disassemble the front end, whew!
Once you have the lock out take the black plastic cover off and remove the electrics. There is a micro switch there that you can close with a small zip tie that will 'fool' the bike into thinking the lock is still fitted. If you don't do this the bike will not run.
Put this assembly into a watertight bag and it will fit neatly into the space between the pv motor and the oil tank.
Reassemble and you are done.
I am working on a 'plug in' at the steering lock electrical connector that will negate the need to retain the steering lock electrics on the bike. I hope to have that info available in the next few days.
I am also having a blanking plate made to fill the hole left by the lock, it is a huge and very heavy item!, and recommend this for two reasons:
#1 Whilst the lock assy is low grade cast alloy it may provide some rigidity to the steering head, JHA used to make a higher grade replacement item as a 'race' part. Why take a chance? Once I have an accurate template I will be happy to share this.
#2 It will keep any crap from getting to the steering head bearings.
If MC28's were lemons they would be nice big fat ones so losing over half a kilo can't be too bad!.... Just be careful where you park it!
NSR-lizard
Tue Jul 13, 2010 5:33 pm » Post: #8 » Download Post
Just park it next to an MC21! No one in their right mind would take the MC28 then! ROTFLMAO
Vampire?
caffeinejoe90
Mon Jul 19, 2010 12:18 pm » Post: #9 » Download Post
NSR-lizard wrote:Just park it next to an MC21! No one in their right mind would take the MC28 then! ROTFLMAO
Agreed,
as most thieves are lazy and wouldn't know the 28 was without a lock they would target the older/dated bike with the earlier, rudimentary security lock mech....
Also, most stolen bikes are broken down for parts and as the 21 is more common along with being older/dated they would be more likely to easily move the parts....
so, good point, rather than buy an expensive alarm for my modern and desirable 28 I'll buy one of a hundred doggy old 21's that are commonly available to divert attention.
Thanks
Smile
MC28SP
KLX110 hotrod
CAG Minimoto
1997 WRX
21 Speed Bike
162 Smurfs
diviCe
Mon Jul 19, 2010 12:58 pm » Post: #10 » Download Post
Agreed,
Thanks
Smile
ROTFLMAO
