The F-III kit doesn't use them, but only because the HRC ignition system has no provision for them. For street use, and even track applications without the Formula III ignition I would leave them in place. They significantly smooth the power curve. _________________ Andy.
Large carbs on the motors we have tested on the dyno generally lose you bottom-end and mid-range, and rarely produce more power than the OEM 32mm items, although can give additional over-rev if the motor is capable of making power that high up the rev range.
The PGM-II, PGM-III, and PGM-IV all have an ignition curve that expects the air correctors to be in place, and triggers the solenoids for best performance. You will likely run rather rich at various throttle openings/RPM without the solenoids... which is one of the problems we've encountered with the PJ/PWK equipped bikes with non-F-III ignitions. _________________ Andy.
You would be beter off boring out your carbs or fitting mc28 carbs to your bike . Been there done that . When i put 38's on , i could not kickstart the bike and saw no extra hp on the dyno . Fact !
