Blanking air solenoids
NSR-LOVER
Sat Aug 21, 2010 10:41 pm » Post: #1 » Download Post
Hi!
i was thinking what could happen if you blank off the air solenoids?
Has anyone tried this? i think that they may be possibly richen my mixture with no reason...
Sat Aug 21, 2010 11:47 pm » Post: #2 » Download Post
The F-III kit doesn't use them, but only because the HRC ignition system has no provision for them. For street use, and even track applications without the Formula III ignition I would leave them in place. They significantly smooth the power curve.
NSR-LOVER
Sun Aug 22, 2010 1:49 am » Post: #3 » Download Post
Yes i understand but if someone fit other carbs pwk etc he has to block them i think...
This doesnt mean that the bike will not perform well
The people who fitted bigger carbs what have they done with the solenoids?
Sun Aug 22, 2010 3:14 am » Post: #4 » Download Post
Large carbs on the motors we have tested on the dyno generally lose you bottom-end and mid-range, and rarely produce more power than the OEM 32mm items, although can give additional over-rev if the motor is capable of making power that high up the rev range.
The PGM-II, PGM-III, and PGM-IV all have an ignition curve that expects the air correctors to be in place, and triggers the solenoids for best performance. You will likely run rather rich at various throttle openings/RPM without the solenoids... which is one of the problems we've encountered with the PJ/PWK equipped bikes with non-F-III ignitions.
Neal
Sun Aug 22, 2010 7:17 am » Post: #5 » Download Post
You would be beter off boring out your carbs or fitting mc28 carbs to your bike . Been there done that . When i put 38's on , i could not kickstart the bike and saw no extra hp on the dyno . Fact !
Sun Aug 22, 2010 4:08 pm » Post: #6 » Download Post
I think I'd rather have PJ's on mine than MC28 carbs! Not because they are MC28, but because they are a tw*t of a carb to work on!
A 2 minute job to changes the needles in PJ/PWK's, a 4 minute job with MC18/21 carbs, and a 25 minute job for an MC28!
I think the MC18/21 carb venturi is better than the MC28 too, personally.
Neal
Sun Aug 22, 2010 4:19 pm » Post: #7 » Download Post
How about someone modifying the bowls on the 21 carbs for a quick jet change ?
Sun Aug 22, 2010 4:30 pm » Post: #8 » Download Post
Yeah, that could be a good mod. Not sure how practical it is, but could be worth a try.
Middo
Sun Aug 22, 2010 11:46 pm » Post: #9 » Download Post
And while they're at it swap the idle air-screw on the left one to the other side......
nsrdownunder
1993 Honda nsr 250 mc21 sp
Mon Aug 23, 2010 8:49 am » Post: #10 » Download Post
Yeh that left air screw is hard to get to . I think something like the idle adjuster would be perfect easy adjustments without pulling anythink off.
bandit_7
Mon Aug 23, 2010 10:01 am » Post: #11 » Download Post
I must have very nimble and feminine hands as I can adjust the air screws with a screw driver and a torch.
The torch is because I'm blind as a rivet.
Bandit7
