Front brake switch
80XAR
Front brake switch
Fri Sep 24, 2010 6:46 am » Post: #1 » Download Post
Is the front brake switch of the MC21 (35340-KV3-700) interchangeable with any other model honda's ? IE CBR250, older CBR900's ect ?
Tried to do a search, but got an error and a 'debug' mode warning type thingo come up Embarassed
Fri Sep 24, 2010 7:22 am » Post: #2 » Download Post
I can't believe it's actually a KV3 part. That implies it's an NSR only (or NSR originally) part.
I've been to the local breakers and asked for "a 1990's Honda front brake switch" and what they gave me (for £2) fitted, it's highly unlikely they broke an NSR.
80XAR
Fri Sep 24, 2010 10:53 pm » Post: #3 » Download Post
Cheers mate. It 'looks' like a common thing. I might try your trick and take it down the wreckers and ask the same question. Smile
Last time i went there, i scored a brand new L/H switch block, that hadn't been modified to keep the lights on. I turn them completely off during the day.
I relish the extra 0.5hp gained from less ignition drag from driving the 2 x 30watt tyga headlight bulbs !!
RZRob1
    Send private message View user's profile AIM Address
Sun Sep 26, 2010 8:45 am » Post: #4 » Download Post
I just replaced mine this weekend, the part number is 35340-MM5-600 and the switch is identical. Hope this helps.
Glen
Sun Sep 26, 2010 10:26 am » Post: #5 » Download Post
My best guess is yes.. However is the CBR250 brake/clutch lever identical to the NSR250 ones??
Paranoia about failure will ensure nothing but failure to ever reach potential.
MC18 Race bike project..
MC21 Race bike..
Middo
Sun Sep 26, 2010 11:33 pm » Post: #6 » Download Post
RZRob1, do you know what model that part number was for? It would be good to know if it was from a model that was an "official" import.
RZRob1
Mon Sep 27, 2010 2:31 am » Post: #7 » Download Post
I looked extensively on Google for the correct part, searched 35340-KV3-700 part number and the local dealers that resulted in the Google search cross referenced this part number to the one I previously noted above. There were three that came up: 35340-ML4-005, 35340-MM5-600, and 35340-MA5-671. The local Honda dealer said the second part number superceded the first and the photos looked correct and it is. Its an OEM part from Honda and I think Honda uses it on many bikes the results showed VTX1300C, CB400F, and 929RR. Do a Google search, second page lists them all.
