Is the front brake switch of the MC21 (35340-KV3-700) interchangeable with any other model honda's ? IE CBR250, older CBR900's ect ?
Tried to do a search, but got an error and a 'debug' mode warning type thingo come up _________________ Winning isn't everything, but loosing isn't anything
I can't believe it's actually a KV3 part. That implies it's an NSR only (or NSR originally) part.
I've been to the local breakers and asked for "a 1990's Honda front brake switch" and what they gave me (for £2) fitted, it's highly unlikely they broke an NSR. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
Cheers mate. It 'looks' like a common thing. I might try your trick and take it down the wreckers and ask the same question.
Last time i went there, i scored a brand new L/H switch block, that hadn't been modified to keep the lights on. I turn them completely off during the day.
I relish the extra 0.5hp gained from less ignition drag from driving the 2 x 30watt tyga headlight bulbs !! _________________ Winning isn't everything, but loosing isn't anything
My best guess is yes.. However is the CBR250 brake/clutch lever identical to the NSR250 ones?? _________________ Paranoia about failure will ensure nothing but failure to ever reach potential.
I looked extensively on Google for the correct part, searched 35340-KV3-700 part number and the local dealers that resulted in the Google search cross referenced this part number to the one I previously noted above. There were three that came up: 35340-ML4-005, 35340-MM5-600, and 35340-MA5-671. The local Honda dealer said the second part number superceded the first and the photos looked correct and it is. Its an OEM part from Honda and I think Honda uses it on many bikes the results showed VTX1300C, CB400F, and 929RR. Do a Google search, second page lists them all.
