Hi All i'm about to get a mc21 totaly standard including oil pump which 2 stroke oil do you all recomend? i know it's got to be fully synthetic i live in leeds so most oils are avalible there is a motorcross shop 2 minutes from my house is the oils you mix in with petrol ok to use? or does have to be injected oil? also i would imagine using the same oil all the time would be best but i dont know which has been used so as long as it's fully synthetic oil are they ok to mix in the oil tank then i'l use the same all the time
which is best silkolene,motul,putolene,mobil1,etc
thanks in advance
