Nsr250r7l rebuild won't start
BeauNidle
Mon Sep 26, 2011 8:46 pm » Post: #1 » Download Post
Hi
I am coming to the end of a large jigsaw puzzle that was an nsr250 in boxes and have now got something that resembles the original bike,but unfortunately I cAnt get it to start!
I have fuel, I have compression and I have a spark,but it doesnt want to go at all.
Is it possible to get the ignition timing that far out or something similar? Is there anything in terms of spark timing I may have missed or got wrong?
Any help would be greatly appreciated - I would reallly like to see this bike run again..
2Smoke
1987 Honda NSR250 MC16
Mon Sep 26, 2011 9:05 pm » Post: #2 » Download Post
Umm.. Carbs cleaned? Choke working? Right lead on the right coil?
BeauNidle
Mon Sep 26, 2011 9:20 pm » Post: #3 » Download Post
Carbs have been stripped and rebuilt, choke appears to be working ok.
Is it possible to get the coil leads (or the coils) the wrong way round? I had assumed that the coil with the shorter lead went on the lower pot, and the cable positions in the loom dictated which was which as I couldn't see how you could stretch the upper leads onto the lower coil. Is that not correct?
Mon Sep 26, 2011 10:50 pm » Post: #4 » Download Post
Do the plugs come out wet after you've tried starting it a bunch of times?
Have you tried to bump start it?
Is the battery voltage good?
Harryredchow
Tue Sep 27, 2011 6:13 am » Post: #5 » Download Post
Is the kill switch fitted correctly?
BeauNidle
Tue Sep 27, 2011 7:59 am » Post: #6 » Download Post
I have a spark so I assume the kill switch must be correct. Battery is brand new and the Plugs are wet after I have tried to kick it over but I havent tried to bump it yet as I am using a temp tank hanging from the ceiling and the chain isnt on yet.
Sounds like it is all ok and it should start then - just doesnt want to.
Harryredchow
Tue Sep 27, 2011 8:36 am » Post: #7 » Download Post
Pull the plugs and heat then up with a blow torch to burn off any fuel/oil and put them back in while still warm. Kick it over and do not touch the throttle. You may need a good 50 kicks to sstart it up, but do not be tempted to touch the throttle.
Tue Sep 27, 2011 8:37 am » Post: #8 » Download Post
Harryredchow wrote:Pull the plugs and heat then up with a blow torch to burn off any fuel/oil
Shocked
Tue Sep 27, 2011 12:38 pm » Post: #9 » Download Post
Harryredchow wrote:Pull the plugs and heat then up with a blow torch to burn off any fuel/oil and put them back in while still warm. Kick it over and do not touch the throttle. You may need a good 50 kicks to sstart it up, but do not be tempted to touch the throttle.
Your showing your age now Harry, I havnt heard that one for a long time, the other 'old' alternative was to rub a lead pencil on the end of the plug, dont laugh everybody these methods work, well they used to.
Tue Sep 27, 2011 1:23 pm » Post: #10 » Download Post
Harryredchow wrote:You may need a good 50 kicks to sstart it up, but do not be tempted to touch the throttle.
Indeed, sometimes in my experience they do just go first kick or two, sometimes they can need a good bump start.
This is where being 6ft tall and big/heavy enough to paddle the bike along in gear helps.
Also make sure the battery is fully charged.
2Smoke
Tue Sep 27, 2011 1:24 pm » Post: #11 » Download Post
Still do that now Very Happy
Harryredchow
Tue Sep 27, 2011 2:08 pm » Post: #12 » Download Post
The heating of the plugs always seems to work for me. We used to do it on my mum's Hillman Imp when it was flooded. When I rebuilt my NSR, I had the same problem. Got a bit trigger happy on the throttle, soaked the plugs and no joy. Pulled them out, heat with a small blow torch (only until hot, not red or anything) and replace. Went about 3 or 4 kicks later.
BeauNidle
Tue Sep 27, 2011 5:57 pm » Post: #13 » Download Post
Thanks all, I will try some of these older methods - not sure about the blowtorch but hey - how much damage can i do??
Will report back shortly Smile
BeauNidle
Thu Sep 29, 2011 9:24 pm » Post: #14 » Download Post
Woo hoop - result!!!
Took a flush out of the fuel system and a bump start but it lives!
Thanks all.
nsrjb
Thu Sep 29, 2011 11:08 pm » Post: #15 » Download Post
glad your sorted:)
