Honda NSR 250 SE PGM 3 MC 21 Problems.
George
Fri May 02, 2014 1:32 pm » Post: #1 » Download Post
Hello i need someone to help me.
I have a Honda NSR 250 SE PGM 3 MC 21
Here are the problems
Spark problems
1. No spark on both cylinders
- I check the coils. - they are good.
- Get down at Pulse coils checked successfully.
- Checked the kill switch and ignition switch - they are also good, no shorts or anything, working just fine
- Battery is VARTA funstart 12V 3ah 30A and is 1 year old but i dont know it seems to be good.
I charged it clean the terminals of ignition coils buy new spark plugs and again nothing no spark again on both.
2. PGM III
Today i notice a missing wires from the white terminal of PGM III theye are missing a 3 wires.
At black terminal is a full 16 wires. 8 up and 8 down.
But on white is not like that there is a 6 wires up and 7 down.
I will appreciate any help. thanks
Sorry for my bad English i am from Bulgaria.
nxrsr20
Fri May 02, 2014 9:26 pm » Post: #2 » Download Post
So with the kill switch, with your meter measuring resistance does it change when you turn the kill switch on and off?
What values did you measure for both sides of the coil on both coils?
George
Sat May 03, 2014 9:29 am » Post: #3 » Download Post
Thanks for reply
Here are the measurements
1. Top coil:
LT - 3,2 Ω
HT - 7,75 kΩ
2. Bottom coil:
LT - 3,1 Ω
HT 7,58 kΩ
Kill Switch:
When i test it with my multimeter i put one proble ( the black ) to the frame on the bike and other probe ( the red ) on Black/White cable from kill switch. When its set on RUN reads 24,5Ω but when its OFF there is nothing 0.
I forget to tell my Oil light is not coming up.
For the PGM III i was wrong sorry for that i see on the diagram that is all there no missing wires sorry again.
nxrsr20
Sat May 03, 2014 9:57 pm » Post: #4 » Download Post
What's your battery voltage with the bike off, check with it turned on.
Check the continuity of the ignition and kill switch wiring to the PGM. It should be zero ohms.
George
Sun May 04, 2014 9:42 am » Post: #5 » Download Post
Hello again thanks for help bro.
I check the battery voltage when the bike is off is 12,60 V but when its turned on its 10,60 V
the continuity of the ignition and kill switch wiring to the PGM is good.
nxrsr20
Sun May 04, 2014 7:13 pm » Post: #6 » Download Post
Borrow a friends battery and try and start it with that, it should not drop that low.
What it sounds like is you've lost a cell in the battery so it won't hold up under load.
George
Sun May 04, 2014 9:27 pm » Post: #7 » Download Post
Thanks for reply again men.
That is a good advice i will try it. Hope its work i want to wake up this sleeping beast !
George
Wed May 07, 2014 3:06 pm » Post: #8 » Download Post
Hello champs
I just try a new battery 12V 4Ah from a good friend of mine AND.....
When i turn ignition key ON and kill switch set to RUN this happens
The OIL lamp comes on i was excited to see that
The power valve servo motor moves for the 1st time i see it to goes from middle position on LOW position
Then i measure the voltage when on and off bike
When its all off it reads 12,70 V
When its all ON it reads 12,50 V
AND the moment of truth i just kick it on side stand to check for the wanted spark BUT NOTHING STILL NOTHING on both sides Sad i am so sad and i dont know what to do now.
If anyone can help please i will be here and will wait for answers.
sorry for the language but i am 19 years old bulgarian boy.
nxrsr20
Wed May 07, 2014 8:18 pm » Post: #9 » Download Post
First of all, your English is fine, stop worrying about that. You can understand what an Australian is trying to tell you to do in relatively technical terms so there is no problem with others understanding you.
Some people here are better at riding then fixing, there could be many things wrong, so it is slowly finding each thing and fixing that. When others have the experience, they will chip in.
So have you measure the resistance in the leads from the spark plug cap to the coil?
How are you checking for spark?
Have you checked that you have a good ground signal from the engine to the battery negative terminal?
Have you checked all fuses?
George
Thu May 08, 2014 1:52 pm » Post: #10 » Download Post
The resistance between the spark plug cap to the coil black and green terminal can bee seen in these photos.
LINKS:
TOP coil: https://imageshack.com/i/nf40plj
Bottom coil: https://imageshack.com/i/nhk1d1j
When i check for spark i unscrew the two spark plugs and ground them to the frame of the bike and check for a signal with multimeter on beeping mode always beeps that is good.
And then i set the ignition key ON and kill switch to RUN star start to kick the bike
but there is no spark on both sides i was doing this while is dark at night but i cant hear or see any spark jumping across.
Also i check for signal from Battery negative green cable to engine for signal and on other ground points in bike the signal is good.
I check all 4 fuses. They are all new works fine.
mellorp
Banned
Thu May 08, 2014 4:12 pm » Post: #11 » Download Post
Hi George
Do all the other electrics work, indicators, horn, main lights, stop light ? If so then I would say the problem is somewhere in the kill switch wiring or maybe something is grounding to earth, a wire with broken covering, or even a block connector that has corroded. If possible gently separate the connectors and put some WD40 or equivalent water dispersing spray on the connections. Be careful if cleaning them. search Google for the best method. Release all the clips holding the loom close to the frame and see if any wiring is damaged. You can also check the actual kill switch on the handlebars
Hope this helps
Your written English is very good Smile
No spark
Thu May 08, 2014 5:33 pm » Post: #12 » Download Post
Hi there
does the bike have the stand switch in place ? if it has been removed the wires need bridging together in the block on the loom, If this is so give it a go,
all the best,
jonmac
George
Thu May 08, 2014 7:00 pm » Post: #13 » Download Post
Thanks for the replies guys.
The stand switch is in place and it has never been removed.
When i check for spark i do it without side stand.
I can`t understand one
Where is the positive side and negative side on ignition coils
Each ignition coil have Green and Black terminal
I think the black terminal is negative and the green is positive.
But when i do conductivity test between the Green/Brown wires that are for ignition coils and ground (frame on bike) or engine beeping signal comes. Does this mean they should be connected on Black terminal of ignition coils or not i don`t know or they are the whole problem.
nxrsr20
Thu May 08, 2014 7:55 pm » Post: #14 » Download Post
Follow the wiring diagram
It seems to be right if your multi meter I beeping because it should be low resistance on both.
Johnnymac is correct, even if your side stand is up, check that the switch is working, unplug it and measure it.
George
Fri May 09, 2014 4:31 pm » Post: #15 » Download Post
Hi there
Today i was looking the side stand switch.
I think i found one mistake but who knows so.
There are 3 wires going into the side stand switch
Yellow'Black
Green
Green/White
I check the wiring diagram and see this mistake
Only the Yellow'Black wire was in place on the side stand swtich the other two wires green and green/white was swapped.
Green goes to ground as shown at wiring diagram i check for conductivity between this wire and ground also and to negative terminal of battery and its have strong signal that is good and i plug it in place in the side stand switch so this is done. I was happy to do that its a easy work.
But next other Green/white wire should goes straight into the PGM 3 as shown in wiring diagram and i plug it in place on the side stand switch and when i do conductivity test between Green/White and frame or engine beeping signal comes why is this is right or not?
