Help on starting a MC28
Quazimoto88
Sun Sep 30, 2007 5:45 pm » Post: #1 » Download Post
The bike started and ran fine when I bought it less than a month ago. I rode it home placed it in my garage and covered it. When I went to start it last week. I couldn't get the bike started. I couldn't get it kick started or bumb started. there is enough gas in the tank, the petcock and choke were opened, and the run switch was on.
I am using the original card with no wire splice.
The red warning light is on.
and the dash is flashing the word "off".
any help or ideas would be greatly appriciated, I am new to the NSR250
03 Duc 999, 93 NC30, 94 MC28
Sun Sep 30, 2007 5:56 pm » Post: #2 » Download Post
Did you have the battery on a charger?
If not, check the voltage, I suspect it is too low for the bike to run.
Sun Sep 30, 2007 8:52 pm » Post: #3 » Download Post
"Off" flashing is the run switch on the right hand switch gear FOR DEFINATE.
It says "off" if the run switch is in the off position, "lock" if the steering lock is held on (steering column pressing against the lock), "oil" for low oil, and "err" and a number for problems seeing the powervalve valve servo, throttle position sensor and the like.
So it could be a connection from the plug (it'll be inside a black box with a flip top lid that sit's in front of the power valve servo, it's all under the petrol tank.
Or possibly a faulty switch.
I don't think it can be a fuse, post back if you have no luck or are too scared to get the tank off and I'll whip mine apart, have a check and take a few photos.
See, RGV boys? We can be helpful.............
Sun Sep 30, 2007 8:54 pm » Post: #4 » Download Post
What does it say when you seize solid Fontyyy?
Sun Sep 30, 2007 8:59 pm » Post: #5 » Download Post
I think that's "Err F*ck it!" on the digital display! ROTFLMAO
Sun Sep 30, 2007 9:00 pm » Post: #6 » Download Post
or "$$$"
Sun Sep 30, 2007 9:01 pm » Post: #7 » Download Post
Something about "should have stuck with an RVF" I think Crying or Very sad
Sun Sep 30, 2007 9:02 pm » Post: #8 » Download Post
Should be "$$$" if it's NOT a 250, cos it'll no doubt not be the first and only time!! Wink
Sun Sep 30, 2007 9:18 pm » Post: #9 » Download Post
Now you see, having a normal (non HRC, F3, blah blah blah) 250 pays dividends here as it just means I have to keep an eye out on ebay for a (nother?) barrel and piston set or two for stock. O.E. Honda plating never rips off, so it's not a hours work for even an amateur barrel swapper like me. It really is a bigger job (and a less frequent one) to swap the spark plugs on an RVF.
I wasn't too keen on doing the top on on the road bike though, it was easy enough to get it all back on but getting it off was a right fiddle, bloody oil pump...
Sun Sep 30, 2007 9:23 pm » Post: #10 » Download Post
I don't know why everyone has this affliction for swapping barrels... well, apart from Steve, who has to!
Just ragged the 21 down 60 miles of dual carriageway to Saltash this afternoon, caned the living daylights out of it to Callington and back (anyone who knows what the F3 goes like will have an idea of how hard I had to work the little old SS motor!), and then ragged it back up the 60 miles in 45 mins... in the rain and dusk with no lights! Shocked
I then flicked the kill switch to stop the motor... rather than by expanding a piston into the bore until it was tight enough to stop the crank from spinning! ROTFLMAO
Sun Sep 30, 2007 9:26 pm » Post: #11 » Download Post
Hey I havnt changed a barrel since.... er.. I went back to a 250!
I only take em off now because I like to re ring things! Anyone have a use to 20 sets of HRC piston rings?
Quazimoto88
Mon Oct 01, 2007 6:00 pm » Post: #12 » Download Post
Thanks for the leads guys. I'll let you know what happens. The bike was not on a charger, so I'll start with putting it on a battery tender for a few hours then see what happens.
Thanks again.
Mon Oct 01, 2007 6:14 pm » Post: #13 » Download Post
All the stock NSR's, but especially the MC28, need a good battery to fire them up and run properly.
cgallant
2001 Honda RS250
Mon Oct 01, 2007 8:39 pm » Post: #14 » Download Post
or a lot of pushing, swearing, stomping your feet, more pushing a little more swearing still more stomping your feet, a cold beer and then some more pushing.
I have found that just getting a fresh battery saves some of those steps and leaves more time for the cold beer part.
Charles Gallant
Quazimoto88
Tue Oct 02, 2007 12:38 am » Post: #15 » Download Post
Got the bike started. Just charged up the battery a bit and hooked up a battery tender to it. Hope that solves future problems. Thanks for the help.
