MC18 water pump and power valve
Dmitry
Tue Nov 22, 2011 12:57 am » Post: #1 » Download Post
Was taking a closer look at the motor and noticed this two issues, pictures speak for themselves
wonder how common this is? should I rebuild? where can I get parts?
also looks like some shady tree mechanic have welded the powervalve shaft, so I need the part and some advice how to replace it. Is it MC18 specific part?
cgallant
2001 Honda RS250
Tue Nov 22, 2011 2:00 am » Post: #2 » Download Post
First picture is signs the seal on the water pump shaft is gone...
Dmitry
Tue Nov 22, 2011 3:42 am » Post: #3 » Download Post
yeah, no doubt it was leaking a while, I think the same shady tree mech poured some stop leak in the engine, coolant looks murky. How big of a job is a repair? Parts still available?
Just did the WP on my KTM, had to replace the shaft cause it was all pitted, bearings were toast from water seeping through, also no weep hole on KTM, all water was ending up in the oil. It decided to finally let go big time 500 miles from home. Had to stop every 100 miles to change oil and add coolant.
cgallant
2001 Honda RS250
Tue Nov 22, 2011 1:24 pm » Post: #4 » Download Post
The water seal set is part number 19217-657-023, should check with your parts supplier to see if it's available.
you will need to pull the pump cover, which will require the replacement of the gasket. From there you will need to look at the shaft, bearings and oil seals to make sure they are still good (may need to replace some or all of these). The online parts manual shows a good exploded view of the pump and what parts to look for. The service manual outlines what to inspect for when serving the pump as well.
As for the power valve shaft. My guess is the previous mechanic had some technical difficulties with the reversed threads on the shaft and screwed it up pretty good. His solution was to simple weld the valve control arm to the shaft. Getting the valve out shouldnt be an issue if you can remove the bracket from the cylinder and pry the shaft out (its a press fit). But you will want to replace the entire setup once you remove it...
Charles Gallant
Dmitry
Wed Nov 23, 2011 4:42 am » Post: #5 » Download Post
MC18 parts manual is screwy, part numbers don't match description.
Do I need to pull the whole side case cover to remove pump shaft? reason I'm asking is that I was told on KTM it's just a simple job that can be done by removing only the pump cover but turned out that on my LC4 I had to pull entire pump off and remove shaft retaining clips from the back.
Wed Nov 23, 2011 5:11 am » Post: #6 » Download Post
Whole side cover.
And yes, I know the part numbers are wrong... I already replied to your last complaint about it! When I can find my manual, I will fix it!
Dmitry
Wed Nov 23, 2011 5:21 am » Post: #7 » Download Post
Andy, I'm not complaining, just replying to this below.
cgallant wrote: The online parts manual shows a good exploded view of the pump and what parts to look for.
You guys can just walk in to the Honda shop and order NSR parts, here they don't list any of the parts, even if I give them numbers they don't come up. Can anyone recommend the source for parts that will ship to US?
cgallant
2001 Honda RS250
Wed Nov 23, 2011 12:03 pm » Post: #8 » Download Post
Dmitry,
There are two good places in the US for parts. RedLine Cycle Imports (see the banner at the top of the pages). The other is in your local area, RSCycles. both will be able to get you parts from Japan (if they are still available).
To remove the bearings/seals you will be required to remove the side cover, which would require a new gasket most likely.
Charles Gallant
Dmitry
Wed Nov 23, 2011 12:17 pm » Post: #9 » Download Post
Hmm, didn't even think about Rising Sun, always thought they only deal race bikes.
Thanks!
