Does anyone know if the float height gauge (as shown in the manual) is available in the UK.
I find that there is an oil leak from my bike. It is constant at about 4 drips a day...don't laugh!
I have, for reasons of enjoying myself too much on my MC28, not been concentrating on finishing Noodle (MC21) but now have the space/time and nothing to distract me anymore.
When I finished building the motor I was paranoid about the oil pump system and changed pipes to clear type and lots of other 'paranoid' type stuff.
Anyway with a tank of fresh Super Unleaded, with a little oil added, I took her out for a little run. Started 'First Kick' and ticked over nicely with lots of smoke. Drove about 5 miles not revving to more than 4.5k (after warming up) but the motor refused to run 'clean'! It pulled ok but was hugely rich.
I then put her back onto the ramp and purchased the MC28...you know the rest.
Anyway, full attention back on Noodle I notice this oil leak from the front cylinder at the exhaust joint at its 'highest' point
It is clean engine oil, it's Motul and is not used or burnt oil.
My first thought is that it is oil just running from the tank into the engine and finding the lowest point of exit which, if that is the case, means that the crank case must be full of oil.
Not wanting to sound too much like a dick does anyone have any ideas before taking the motor apart.
Mike, if the oil is not used or burnt it dont sound like its coming from inside the engine, you might want to check your oil reservoir is not leaking ie, pipe loose, cracked, etc, if its fresh oil, where else can it be coming from. Worth a try. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
I hate to sound clever (well maybe not ) but I have two verniers. One Mitutoyu that is about a million years old, but the display has decided to pack up, and a cheap modern one that cost about £12.
I am one of those sad creatures (although I am now at an age when I no longer apologise for it) who like a 'belt and braces' approach.
If the proper toll was around the £20 mark then fine...£40 is a bit steep. But thanks for the info.
I'll have the pipes of tomorrow and see why oil is dripping out of the front cylinder. Can't wait
That's the price from Honda, including the P&P. If I could do anything on it, I would. (Despite what some seem to think! ) _________________ Andy.
Well, for all of you waiting for the next episode of my 'oil leak saga' I think/know that I have now found and cured the problem.
Although the oil looked as if it was coming from around the exhaust manifold area, with a process of kitchen roll pieces placed in strategic positions from the oil pump down, I felt that the leak had to be from the oil pump itself.
I removed the pump in desperation and THEN found the oil trail. I removed the two plates, cleaned all the surfaces and rubber seals and 'lightly' coated them with non setting sealant. Re fitted the pump and there has been no seepage (ooh nurse ) for the last 3 days.
I have not yet run the motor since doing this, but the leak happened before without it running.
Fingers crossed.
Now about this float level gauge!!!
Thanks Dave.
Reading through I see that this is the way that I have done it. I notice that the imortant thing is NOT to let the little spring in the valve assembly compress, just allow it to let the needle point seat!
I did find that on one carb the float height measured differently from one side of the float to the other.
